845 Operating Point
845 Operating Point
Old 11th July 2011, 02:46 AM   #1
gingertube is offline gingertube  Australia
Default 845 Operating Point
Guys,
I'm about to embark on an 845 Single Ended HiFi Amp. I have some good OT's I got from Naz.
On the weekend I started looking at a power supply for this amp.
I have a power tranny 1050-0-1050 at 300mA (with taps at 750V) which will be more than adequate for the job (2 channels).
PSUDII tells me that I will get 1100V DC for choke input supply or up to 1450V using a C-L-C with as little as 5uF for the first cap.
"Popular Wisdom" (if thats not an oximoron) says that something special starts to happen when then 845 is operated at 1250V and above BUT that "wisdom" never states if that is anode to cathode or if it includes a cathode bias allowance (which would be as much as 140 to 150 Volts).
I am going to be fixed biasing. Can anyone offer guidance as to wether I should stick to pure choke input for an 1100V supply or go for a C-L-C and aim for 1250 or more volts.
ASIDE:
Not fussed about caps - I have a bag of about 20 off EPCOS 470uF/450V which I can series parallel for whatever I need.
Thanks,
Ian
Old 11th July 2011, 03:05 AM   #2
Miles Prower is offline Miles Prower  United States
Miles Prower's Avatar
Originally Posted by gingertube View Post
"Popular Wisdom" (if thats not an oximoron) says that something special starts to happen when then 845 is operated at 1250V and above...
More like Audiophool Nonsense. Operating the 845 at higher voltages allows for higher load impedance, and lower Q-Point currents. Both help sonic performance. Triodes always produce less distortion the more lightly they're loaded.
If you get the plate current down, you lessen the problem of DC core magnetization, don't need as wide a gap to prevent saturation, and that helps get the Xlpri up to improve low frequency performance, and make those reactive load ellipses more closely approach loadlines.
Use the 1100V.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 11th July 2011, 08:34 AM   #3
Miles,
That makes sense.
Thanks,
Ian
845 Operating PointHide this!Advertise here!
1J6G recommended operating point? iko Tubes / Valves 7 10th July 2009 04:49 AM
Operating point for 6GK5 AKSA Tubes / Valves 6 6th October 2008 04:21 PM
Best Operating point for a 2A3? sgerus Tubes / Valves 10 2nd August 2006 01:31 AM
6GM8 Operating Point ALBQ Tubes / Valves 2 23rd November 2004 03:45 AM
how to calculate lower operating point? garbage Tubes / Valves 11 18th July 2004 01:43 AM
