| diyAudio Sponsor | ||
I have an Audio Research D76 amplifier with a blown inrush current limiter PTC thermistor TH-1, AR part number 47000. I've found schematics all over the internet, but no identifying parts lists. It's on the primary side of the power transformer, in series with a 5A SB fuse.
Does anyone have a good idea of what the ratings would be on this thermistor? Thanks. |
#2 |
You can find one which works on this page of the DK catalog:
http://dkc3.digikey.com/PDF/US2011/P2185.pdf |
#3 |
The D-76 is fused for 5 amps -- so the KC006L (rated for 5 A continuous) will probably work. I don't know whether this is the device spec'd by AR, however.
| Inrush current limiter | BrianVG | Power Supplies | 15 | 8th June 2011 11:03 AM |
| Current inrush limiter suggestions | EL34Dave | Tubes / Valves | 3 | 17th January 2011 07:08 PM |
| inrush current limiter! | lanchile | Chip Amps | 7 | 2nd February 2009 09:20 PM |
| Inrush current limiter? | roger-k | Pass Labs | 4 | 19th February 2006 07:42 PM |
| Thermistor for Aleph 3 (Inrush current) | Miles Teg | Pass Labs | 18 | 21st October 2002 08:01 PM |
| Page generated in 0.07272 seconds (71.36% PHP - 28.64% MySQL) with 10 queries |
