diyAudio Sponsor
Old 10th July 2011, 03:49 PM   #1
rvrazvan's Avatar
Default 2 PSU sharing the same Power transformer?
Will i have any beneffits from havind two separate PSU(one for each channel) sharing the same power transformer? I want to build a dual mono amp.
I have two similar transformers(shape, power rating), one 220v/220v and one 220v/6.3v. I can rebuild them if it is necessary, but i will lose time doing so.
Old 11th July 2011, 10:08 AM   #2
rvrazvan's Avatar
up up up
Old 11th July 2011, 10:10 AM   #3
DF96 is offline DF96  England
If they share a transformer secondary then they are not separate PSUs. You can separate the outputs, but you probably can't separate the grounds. If you want to build two fairly separate PSUs from one transformer then you need two separate secondary windings.
Old 11th July 2011, 10:33 AM   #4
Two mono supplies means a power transformer for each channel. This means a transformer for high voltage and transformer for filament. it does not means sharing one transformer for high voltage and another transformer for filament needs. I have (2) mono block Quicksilver amplifiers. Each are independant units. There is no cross talk with dual supplies that you have sharing the power supplies.
Sharing gainclone PSU with other circuits rockgardenlove Power Supplies 6 7th January 2011 04:21 PM
briangt PSU 1 transformer, 2 PSU, how to? sansbury Chip Amps 30 28th March 2010 07:26 PM
2 bridged diodes sharing 1 transformer secondary jarthel Power Supplies 17 11th September 2006 04:05 AM
PSU sharing grounds neutron7 Parts 2 5th March 2005 12:23 AM
Power sharing in 3-ways Andy G Multi-Way 3 29th November 2003 10:52 PM
Page generated in 0.08253 seconds (67.15% PHP - 32.85% MySQL) with 10 queries
