| diyAudio Sponsor | ||
I want to bias my firefly amp.
I switched passive cathode ressistor with pot. I need to get 8.8V (cuz it is 8.0) So what should I need to do before biasing? Short input? Volume pots to max or to min? Speaker should be connected or not? What else to do before biasing? Thanks |
#2 |
Always run a valve amp with a speaker or other load connected.
If the circuit says 8.8V and you have 8.0V then you are close enough already. Whenever using a pot for bias you must always ask yourself "what will happen when the pot slider lifts off the track?" In this case, using it as a cathode bias resistor (presumably bypassed by a capacitor), the answer may be "the cap will go bang". I would leave the fixed resistor in place. |
| Marshall Amp Biasing | TubeManiac | Instruments and Amps | 9 | 26th April 2011 12:46 PM |
| Biasing amp | leander | Solid State | 19 | 26th October 2005 12:57 PM |
| low-biasing or high biasing in Class-AB amps | Workhorse | Solid State | 124 | 18th October 2005 04:45 AM |
| How to adjust biasing on amp? | henkel | Car Audio | 4 | 2nd September 2005 04:21 PM |
| Page generated in 0.07755 seconds (68.11% PHP - 31.89% MySQL) with 10 queries |
