diyAudio Sponsor
Old 9th July 2011, 11:00 PM   #1
dgta is offline dgta  United States
Default CCS placement
Suppose we have a simple voltage amp, like the first stage of a Williamson.
We want to improve operation by introducing a CCS. We use a simple BJT or JFET CCS that doesn't take much voltage to operate. So we're able to place the CCS in either the plate or cathode (Assume Vgk=8 to 9V).
Assume the next stage is a direct-coupled concertina, no grid leak. What, if any, advantage(s) would be realized from placing the CCS in the A or K?
How does the answer change if there is more output loading by the following stage?
Old 9th July 2011, 11:12 PM   #2
Alastair E's Avatar
Putting in the Anode-circuit, you can tailor the reference-voltage to get the phase-splitter grid-voltage correct, for optimum operation....
Das Beste Oder Nichts
Old 9th July 2011, 11:58 PM   #3
SpreadSpectrum's Avatar
I'm having trouble understanding what you are getting at. If you put a ccs in the cathode of the first stage, you will get no gain as the ccs will try to cancel out the input signal.
If you don't have equal loads on a concertina, you will have an unbalanced splitter.
Old 10th July 2011, 01:02 AM   #4
Spread, I assume you can avoid cathode degeneration by bypassing the cathode, no?
As to the concertina, you misread. I'm not proposing a CCS in the concertina, only in the voltage amp. I will edit for clarity.
Oops, too late to edit my original post. Sorry.
Old 10th July 2011, 01:33 AM   #5
Ahh, yes. That makes more sense.
CCS in the cathode (assuming it is bypassed) is going to give a more stable current than a resistor, otherwise it is about the same as a resistor.
I would put the CCS in the anode where it will improve linearity and offer more gain. I would also bias with LED in cathode circuit.
Old 10th July 2011, 04:42 AM   #6
Do you know any LEDs that work well at 2mA?
Old 10th July 2011, 02:35 PM   #7
DF96 is offline DF96  England
Remember that with a triode there is a relationship between Vg, Va and Ia (and this relationship changes with ageiing). You can fix any two of them and the triode will attempt to set the third. Fix Ia (with a CCS) and Vg (with an LED) and Va will then set itself where it chooses. The result is that you will need to keep adjusting the CCS as the valve ages, otherwise the phase splitter could get upset.
If using a CCS in the anode, I would use a resistor in the cathode so that the necessary adjustment is shared between grid and anode voltage. This gives better long-term stability. This issue is less of a problem if the next stage does not use DC coupling.
Old 10th July 2011, 02:51 PM   #8
SY's Avatar
With a CCS in the plate, nearly all of them.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 10th July 2011, 05:30 PM   #9
Yes indeed. I haven't done much reading on the LED biasing, but my understanding is that LEDs are essentially used as a fixed voltage reference. With a CCS, seems to me you have the same thing already. A constant current across the fixed (cathode) resistor.
Old 11th July 2011, 02:35 AM   #10
I'm having trouble understanding how a resistor would give more DC stability than the LED. Like dgta said, fixed current through a resistor gives a fixed voltage, independent of the tube in the circuit.
I would think that the LED would be slightly better. With real world CCSs, AC impedance will not be infinite so there will be some small AC voltage at the cathode in the case of the resistor. In the case of the LED, this will be less due to the (presumably) smaller AC impedance of the LED. True, this may be an insignificant improvement but I like to take better when it comes at no additional cost. If I can't find an LED with the right forward voltage I would have no problem using a resistor, though. I have to admit that another draw to the LED solution is that it glows.
tonearm placement garethjones Analogue Source 6 19th March 2009 07:02 AM
Placement lpd Planars & Exotics 0 20th August 2008 11:39 PM
sub placement chainenoble Subwoofers 3 13th October 2006 03:45 AM
Buschhorn placement MichaelK Full Range 3 25th November 2005 05:34 PM
CCS Conceptual Qs, Using Gary Pimm CCS as Example DrDeville Tubes / Valves 20 12th May 2004 02:41 PM
Page generated in 0.10664 seconds (75.89% PHP - 24.11% MySQL) with 10 queries
