diyAudio Sponsor
Old 9th July 2011, 05:01 PM   #1
Default Popping in stepped volume control
I have a stepped volume control on a tube preamp. It is a series resistor design. Lately, when I turn it, it emits a fairly soft pop. Also, when I tap on the preamp, I'll sometimes get a sputter. I think the cause might be a tube (replaced one), but I seem to remember this being a longer standing problem on and off than the life of a tube. Obviously, I could simply resolder every joint, but I wonder if there is any particular place I should look. If not, I'll do more tube swapping and soldering.
Trombone
Old 9th July 2011, 05:15 PM   #2
Minion is offline Minion  Canada
I seem to remember with Stepped attenuators that you need to get the "Make Before Break" type of stepped switch to aviod pops ..... I don"t know if this is your issue .....
Old 9th July 2011, 05:31 PM   #3
I don't think so. These are pretty good pots, and the problem is only one side.
Trombone
Old 9th July 2011, 05:36 PM   #4
Frank Berry's Avatar
You may have a bad coupling capacitor on the input or output side of your stepped volume control. A little DC leakage through the capacitor can cause this problem.
Frank
Old 11th July 2011, 03:57 AM   #5
I had that problem when I reused some tube sockets one time.
swap the attenuators from left channel to right channel. if the problem follows, repair the attenuator, otherwise its most likely a tube socket or bad solder joint on grid stop resistor (if it has one)
Old 11th July 2011, 08:11 AM   #6
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
That's the most likely cause. If you have some DC on the pot line(s), switching that pot will cause a DC step which will he heard as a tick or pop.
jan didden
/Another new issue: Linear Audio Volume 3!
www.diykits.com.hk stepped volume control ... any good? kvk Tubes / Valves 19 23rd April 2008 08:10 PM
PLLXO with stepped volume control? Dartagnan Multi-Way 8 6th October 2004 04:17 PM
Noble/Alps stepped volume control gjo Parts 0 11th March 2004 09:15 AM
Volume Control via logrithmic stepped attenuator PaulHilgeman Solid State 4 6th February 2003 11:51 AM
Gainclome Volume Control using Log Stepped Attenuator PaulHilgeman Parts 10 5th February 2003 08:40 PM
Page generated in 0.09622 seconds (71.61% PHP - 28.39% MySQL) with 10 queries
