diyAudio Sponsor
Old 9th July 2011, 04:31 PM   #1
Default 6by5 CRC Values
Hi all, I want to use parallel 6by5 rect. tubes in my 16LS kit from S-5 Electronics. The PSU will be a fairly simple CRC filtered type not too far off from the spec'd setup from S-5. The first filter cap in the stock setup is 220uf then comes the 470 ohm 1W resistor and then a 100uf. I know I can play around with the resistor value 'till my heart's content but something tells me that this 220uf first cap is too large. Since the 6by5 was meant for tv damper serivce I cannot find much info on what would be a good (safe) value for the first filter cap. "Anyone...anyone...Bueller"
Old 9th July 2011, 04:56 PM   #2
Zibi is offline Zibi  Poland
6BY5, Tube 6BY5; Röhre 6BY5 (6BY5)
Old 9th July 2011, 05:58 PM   #3
Vinylsavor's Avatar
Hi!
Don't torture tube rectifiers with input caps that large. The 6BY5 is more fragile in this regard as other TV Dampers. You could split the resistor and move one half upfront of the first cap to limit charging current pulses.
Get the power supply design software PSUD. It is free on duncanamps.com It helps you to design your PSU and to simulate the peak current through the rectifier.
Best regards
Thomas
http://vinylsavor.blogspot.com/
Old 9th July 2011, 07:45 PM   #4
vinylkid58's Avatar
"Twist and Shout"
+1. I think the 5V4-G rectifier option is close enough for modeling a 6BY5 in PSUD.
jeff
Old 9th July 2011, 10:39 PM   #5
Thanks Zibi, looks like 8uf for 1 tube. I also notice the 100 ohm resistors on the inputs to the tube. Are these necessary because I have seen other designs without them. Just wondering what their purpose is here.
Old 10th July 2011, 10:10 AM   #6
Vinylsavor's Avatar
Hi!
The 100 Ohm resistors limit the charging current pulses.
It is not the cap size which is the limit, but those pulses. You can control them either by the size of the cap or by such resistors.
Thomas
Intermodulation Distortion Values below THD Values by SS Amps - is this possible ?? tiefbassuebertr Solid State 28 30th May 2011 11:20 AM
CRC Filter ? kacernator Tubes / Valves 2 31st July 2009 10:15 AM
CRC filter values....method? (w/schemo) redrabbit Power Supplies 8 23rd October 2006 07:05 PM
6BY5 High Voltage & High Current Choke Input Design P.S. snoopyma Tubes / Valves 7 28th June 2006 01:32 PM
Crc Clc ?????? chipco3434 Pass Labs 3 11th July 2005 06:52 PM
Page generated in 0.09798 seconds (74.71% PHP - 25.29% MySQL) with 10 queries
