Hi
I wont to build this project http://analogmetric.com/download/12A...0Schematic.pdf Manual http://analogmetric.com/download/12A...r%20Manual.pdf I have two problems: 1) value of the C6 is different in the schematic and BOM - what should it bee 0,01uF or 0,22uF 2) I need help with capacitor picking,i wont to give fallowing capacitors: C8 and C9 Russian oil cap C6 Wima black or Russian teflon C1 Russian oil cap C3 ordinary Red Wima What do You Think, what other capacitors would be better ?? I have about 50-80$ for those capacitors. THX for any help. |
#2 |
C6 is not very critical but 10nF seems a bit low. 100-200nF will be fine.
Why would you want to build such an old fashioned Marantz 7 clone? Nostalgia? |
#3 |
No
this project seems to bee pretty decent so i have decide to build it but if You know any better tube pre-amplifier support MC cartridges please insert schematic.
#4 |
#5 |
If you're using MM cartridge you'll want to eliminate the grounded-grid input stage and go straight into the second tube.
#6 |
I have built using this schematic 3 years ago. The value of C6 I use is 0.01uf. I purchase pcb board from Hong Kong (China made). It's modified from VTL ulitimate , not Marantz 7.
It sounds excellent, I love it and still use it until now. |
#8 |
VTL version is very different from Marantz 7. They both use 3 12AX7 stages but other than that it's not the same and the most important thing they sound different.
Schematic of Marantz 7 phono. http://www.kitsparts.com/shop/downlo...pdf/M7_Sch.pdf |
#9 |
What makes you think the circuit in the link is a Marantz 7? Looks like a free interpretation by another kit seller. Passive riaa???
| Phono MC/MM who is running balanced? | Bksabath | Analogue Source | 28 | 1st September 2011 03:16 PM |
| FOR SALE: PASS XONO clone MM/MC phono stage DIY | marknoir | Swap Meet | 13 | 20th April 2011 04:01 PM |
| MC/MM Phono Pream PCB | gabrielbecheanu | Tubes / Valves | 3 | 9th October 2010 09:11 AM |
| Musical Surroundings MM/MC Phonomena Phono Preamplifier | kp93300 | Analogue Source | 0 | 11th October 2009 01:15 PM |
| Black Cube MM/MC Phono Amp for sale | Boban | Swap Meet | 3 | 27th August 2003 02:15 AM |
