#81 |
Has anyone used or seen the Marantz 7 phono preamp PCBs? Can you tell me which is better, this one or Jim's Audio? Tube Phono RIAA Stereo Pre Amplifier PCB Marantz 7 | eBay
#82 |
The only thing worse than ripping off the Marantz trademark to sell cheap boards is ripping off the Marantz trademark to sell cheap boards that have nothing to do with the Marantz circuit. Not that the Marantz circuit was all that great, but still, this is absolutely terrible ethics. If they'll steal from Marantz, don't you worry that they'll steal from you?
If there's a sucker born every minute, where do the rest of them come from? |
#83 | |
#84 |
I'm also in the Chicago area (Lake County), and they wanted to put me into Signal Corps back in the draft days (I was well aware of the life expectancy of a 2nd Lt in SC, which approached zero as an asymptote). So you have my sympathy and understanding.
If you can lay out what it is you want the preamp to do (gain, impedance, phono or not), people here may have some suggestions on reputable vendors of good quality designs.
#85 | |
#86 |
Ann Arbor is a great town, you'll enjoy it.
Most of the Chinese "Marantz" pres will have a struggle driving the low-ish input impedances of a solid state amp. You might look at something like an Aikido from John Broskie. There's probably a lot of decent designs out there in kit form with some oomph that will work well for you.
#87 | |
#88 |
Just got hold of the another schematic (DIY Gene).
(I built the AnalogMetric version some time ago with a few alterings.... Sowther step-ups, running mm-mode with 6.3 volt filament and 4 6N2P-EV instead of 12AX7, have probs. with a slight humming still, and of course the lack of bass, other than that the sound is quite good.) The schematic differs in these points: R 14 is 1Mohm R 15 is 1Kohm R 16 is 24Kohm. This is the only difference, C6 is still 10nF. Anyone on what this would do??? |
#89 | |
SP-6 Light with ECC801S on the horizon already. Please check it out. It would seem that the pre-amp fizzles out over time. Maybe you can send suggestions their way? |
#90 |
Anybody knows what is the output resistance of this chineese 12AX7 shematic? I don't know how to measure it.
| Phono MC/MM who is running balanced? | Bksabath | Analogue Source | 28 | 1st September 2011 03:16 PM |
| FOR SALE: PASS XONO clone MM/MC phono stage DIY | marknoir | Swap Meet | 13 | 20th April 2011 04:01 PM |
| MC/MM Phono Pream PCB | gabrielbecheanu | Tubes / Valves | 3 | 9th October 2010 09:11 AM |
| Musical Surroundings MM/MC Phonomena Phono Preamplifier | kp93300 | Analogue Source | 0 | 11th October 2009 01:15 PM |
| Black Cube MM/MC Phono Amp for sale | Boban | Swap Meet | 3 | 27th August 2003 02:15 AM |
