#61 |
I bought only the pcb, all the parts are very good quality caps from Nichichon and the semiconductors from Farnell non polar caps from Vishay but the hum still is
#62 |
#63 |
Valve is "controlled" by grid-cathode difference. Doesn't matter which is at "ground".
#64 |
I have checked the solder connection n they seem good, I made a aluminium coated plastic cover for the transformer n nearly all the hum went away, the rest went when i cleaned all the earth terminal. No more hum but a little buzz which i attribute to placement of input wires...I have intermittent signal on left channel but i will wait till i get new rca sockets n valves. I am using a Thorens TD280 Mk II, coupled to a Acurus L10 line pre amp and Acurus A250 power amp. Bass is ok but what can I do to increase it.
#65 |
I am at 400k in R14. Bass is pretty good. The output will start to oscillate much over 500k.
I have very little hum or buzz. |
#66 |
Some years ago I also have purchased this kit from Analogmetric. It seems to me, that sound was a bit better after C8, R15 ( shortened ) and R14 were removed, but R16 changed to 56K, capacitor C11 consists of two 10n in parallel, C6 - Russian K72-6 0.033uF, you can see it on e-bay x8 0.033uF 500V AUDIO teflon capacitors K72P-6 | eBay. I listened it with MM only.
#67 |
Is the MC quiet enough?
Robert Lounge Audio |
#68 |
Havn't tested. Sorry for mistake is last post - C11 - two 10n in series.
#69 |
400 k sounds good, still getting buzzing in both channels at 1/2 volume. Btw, my power supply is really hot esp the 12volt regulator..any advice?
#70 |
Did you connect the heater GND and B+ GND together or elevate the heater GND?
Did you connect both 260v B+ together? I see only 1 being powered in your pic. I would also twist the mains on the right side tighter and without the earth GND and get them away from the power supply board. Last edited by marsvolta; 20th June 2012 at 07:12 PM. |
| Phono MC/MM who is running balanced? | Bksabath | Analogue Source | 28 | 1st September 2011 03:16 PM |
| FOR SALE: PASS XONO clone MM/MC phono stage DIY | marknoir | Swap Meet | 13 | 20th April 2011 04:01 PM |
| MC/MM Phono Pream PCB | gabrielbecheanu | Tubes / Valves | 3 | 9th October 2010 09:11 AM |
| Musical Surroundings MM/MC Phonomena Phono Preamplifier | kp93300 | Analogue Source | 0 | 11th October 2009 01:15 PM |
| Black Cube MM/MC Phono Amp for sale | Boban | Swap Meet | 3 | 27th August 2003 02:15 AM |
