| diyAudio Sponsor | ||
Hi, im new in tubes.
Have just assebled a 2x16 watt AMP. Id like to use my stax headphones (electrec type) that are driven with speaker output. Is that load ok for tube AMP? Or how do i calculate??? Thanks and sorry for the simpel question!!! Best regards D. Loncar |
#2 |
doesnt anybody have any expierience with that? or knowledge?
br d.loncar |
#3 |
Perhaps if you gave the schematic or model of the amp, and the model of the headphones, someone might know something.
http://www.ecpaudio.com |
#4 |
AMP 2x16 watt from tubedepot.com and stax sr40 electret headphones.
#5 |
#6 |
16 watt sounds a bit high for headphones, maybe you should try a dummy load with a potential divider on the speaker out, that should keep the impedance but lower the power for headphones. but im not sure about the electret headphones, and how levels will affect them
#7 |
#8 |
Are you using an srd-7 adapter with the amp for the stax? If so you will be fine - its an easy load for the amp.
Visit www.tirnahifi.org!! |
#9 |
Your amp should power the headphones without a problem.
Be aware that the headphones can reproduce the audio accurately but they can't deliver high sound pressure levels.
Frank |
#10 |
Thanx for the replies. Its these two:
Model 16LS Stereo Integrated Tube Amplifier And Googles billedresultat for http://i-cdn.apartmenttherapy.com/uimages/unplggd/031111SR40.jpg |
| Headphones with a Tube Amp | bwarden | Tubes / Valves | 19 | 30th June 2011 06:52 PM |
| Speaker tube amp with headphones | Simpleton | Tubes / Valves | 6 | 7th April 2005 03:01 PM |
| Stax electrostatic headphones | npdang | Swap Meet | 0 | 21st October 2004 07:33 AM |
| $5.99can for STAX headphones | seangoesbonk | Multi-Way | 2 | 7th June 2003 11:15 AM |
| Page generated in 0.10234 seconds (76.46% PHP - 23.54% MySQL) with 10 queries |
