diyAudio Sponsor
Old 8th July 2011, 02:35 AM   #1
H.Michi is offline H.Michi  Japan
Default The Telefunken EF86?
Is anyone knows about background of this tube?
I bought 4 tubes which described as NOS Telefunken EF86, without notation even product name at German Ham fair in Fridrichshafen. They were put in the bulk package box. the price was 8 eur per tube.
Old 8th July 2011, 04:12 AM   #2
astouffer's Avatar
Telefunken should have a diamond shape stamped into the glass on the bottom of the tube.
Old 8th July 2011, 07:06 AM   #3
Thank you for your reply.
I can see a square mark (may be diamond) in a circle on the bottom of the tube.
Old 8th July 2011, 03:52 PM   #4
as I rememberred, ef86 was Telefunken's take on the 7199 tube.
refinements of this tube design was later introduced as ef 806
Old 8th July 2011, 06:40 PM   #5
7199 pentode stage of course, 6sj7. 6j7,
Old 8th July 2011, 06:52 PM   #6
kevinkr's Avatar
Actually the EF86 is not anyone's take on the 7199, it is a moderate transconductance low noise pentode designed for low level audio applications with low microphony being a major point of the design. The US equivalent is the 6267 IIRC.
Those tubes don't look anything like any EF86 I have seen, doesn't mean they aren't but can you get get better pictures of the plate structure? Not sure if it is a single which is what it appears to be - the pictures make it hard to tell.
Telefunken made good 6U8A and 6BL8 and I am wondering if these could be one of those? (Probably wrong) If they are indeed what they are represented to be they should be very good.
www.kta-hifi.net
Old 8th July 2011, 10:16 PM   #7
kstagger's Avatar
I used to be a bit of an EF86 'collector' and those certainly don't look like any Tele EF86 I've ever seen. The Telefunken EF86s I owned had nickel plates. The ones pictured almost look like Teslas... ???
Old 8th July 2011, 11:48 PM   #8
astouffer's Avatar
The few EF86s in my collection look like the ones posted except lighter grey colored plates and orange Amperex logos. For some reason all the Amperex pics I can find are the mesh plate type.
Old 9th July 2011, 12:00 AM   #9
vinylkid58's Avatar
Appears they came with a grey OR silver shield. Take a look on the tubeworld page:
https://www.tubeworld.com/6267.htm
jeff
Old 9th July 2011, 03:52 AM   #10
Maybe OP has some Russian equivalents on his hands?
Ef86 trancy Tubes / Valves 44 2nd February 2012 07:38 PM
EF86 replacement Hojvaelde Tubes / Valves 22 3rd September 2009 04:46 PM
EF80 vs EF86 newbadboy Tubes / Valves 3 11th April 2008 01:54 PM
EF86 Gm dsavitsk Tubes / Valves 7 31st March 2007 07:59 PM
EF86 penthode specter73 Tubes / Valves 8 7th December 2005 05:38 PM
Page generated in 0.10660 seconds (79.82% PHP - 20.18% MySQL) with 11 queries
