diyAudio Sponsor
Old 7th July 2011, 03:02 PM   #1
Troncones's Avatar
Default Can you run parallel circuits from a rectifier?
I picked up a set of 2A3 mono blocks that I would perfer to build into a single amp. Unfortunately the mA rating on the chokes is to low to use just one of them. The HT Tx's are 450-0-450 so I would use a single Tx that is more suited to the 2A3. The mono blocks use a resistor to bleed off 33mA and produces 10 watts of heat that I want to eliminate. (They were built from salvaged pieces he had on hand)
So I was wondering if I could just parallel the circuits at the rectifier. I have omitted some detail in the attached sketch and hopefully just indicated the components and values that would have an impact on the rectifier. To model the load in PSUDll I would use a single side of the circuit and use H/2, R/2, uF*2, mA*2 for values.
Can I do this?
The Myth: A hand full of Tubes, Caps, Resistors and Iron and you have an Amp. The Reality: You have self induced Dementia. Newbie.
Old 7th July 2011, 03:08 PM   #2
kmaier is offline kmaier  United States
kmaier's Avatar
Sure, or you can parallel the chokes if you prefer a single supply.
Fi does a dual pi-filter off one rectifier:
http://www.6moons.com/audioreviews/fi5/hero_open.jpg
Regards, KM
... just because you're paranoid, it doesn't mean they're not after you...
Old 7th July 2011, 03:56 PM   #3
Troncones's Avatar
Thanks KM,
I didn't think of paralleling the chokes. But now that you mention it, would keeping the circuits parallel and using separate caps for C1 offer better sound quality?
Old 7th July 2011, 06:37 PM   #4
kmaier's Avatar
As you're combining into a stereo amp I'd follow Don's lead (Fi pic), separate chokes/caps for each channel. You get some (power supply) isolation between channels. Note that if you use an indirectly-heated rectifier (5V4G, 5AR4) you would use pin 8 for a single cathode connection.
Regards, KM
Old 7th July 2011, 08:18 PM   #5
nigelwright7557's Avatar
Its better to parallel the supplies than to run one single power supply.
You can get crosstalk on a single supply to two pre amps.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
parallel tube rectifier filaments dobias Power Supplies 3 27th May 2011 01:18 PM
Any benefit to DC heater on parallel supply rectifier (GZ34)? leadbelly Tubes / Valves 2 13th February 2006 11:00 AM
Short 75R connections - twisted or parallel run fmak Digital Source 5 28th January 2006 02:13 PM
can I run 2 torroid in parallel operation? ericpeters Solid State 10 24th November 2004 05:08 AM
What if aleph-p is run in parallel? PatPet Pass Labs 4 2nd August 2004 02:42 AM
Page generated in 0.08000 seconds (72.19% PHP - 27.81% MySQL) with 11 queries
