| diyAudio Sponsor | ||
Hi guys,
I am now having a terrible problem, pls help me! I changed the drive tube and when I was adjusting the bias of the diver tube to 10mVDC relative to each other at the two bias adjust point, A resistor blew up out with smoke. I don't know what kind It is and where to buy it. PLS help me!I can not take it to AR agent, because not available in my country from Asia. I just can buy it from somewhere out, ship to my home country and replace it then.Pls note that this resistor connect to a transitor(may be) with the heating free on it. Mny tks to your help. ASAP pls! I am down with nervous! This í some pictures of it. ![]()
#2 |
Audio Junkie
you can contact Chris Ossana at Audio Research directly. contact information is on the website. he should be able to sell you the part directly plus give you service information.
Zc
It's not about what you can BUY...It's about what you can BUILD! |
#3 |
#4 |
Tks Zero Cool,
I am not actually familiar with this. I could not find Chris Ossana email or phone on the audioresearch.com. Could you pls kindly get me his email on here? Gratefully! |
#5 | |
Mny tks! |
#6 |
This repair is very simple for someone who knows what they are doing. Even if the unmarked mosfets are also blown. Getting tips from a forum is a lot riskier. I hate seeing nice equipment getting destroyed.
#7 |
So, could you give me some reasons for this blow? Could it be new driver tube? I change the 6922 with used bugle boys that I think of improvement in sound quality. Or may be I adjusted the bias point too fast, or sth else?
#8 |
Audio Junkie
a shorted tube would most likley be the culprit. you may have other damaged parts now as well.
#9 |
#10 |
If you have to ask, chances are you may cause some further damage. Do you solder well? Can't you get a good TV repairman to fix it for you?
| Schematic of Audio Research VT 100 | Alex helge | Tubes / Valves | 8 | 1st September 2011 12:16 AM |
| Upgrading my Audio Research VT 130 SE Tube amp | Serratoga | Tubes / Valves | 16 | 20th March 2008 01:15 PM |
| Audio Research REF 2 MkII | Real_Macgyver | Tubes / Valves | 0 | 30th December 2005 07:52 AM |
| Need schematic - Audio Research LS2B MKII | ruangrit | Tubes / Valves | 0 | 5th January 2005 12:32 PM |
| Page generated in 0.10650 seconds (77.99% PHP - 22.01% MySQL) with 10 queries |
