diyAudio Sponsor
Old 5th July 2011, 05:25 AM   #1
wrenchone's Avatar
Default Triode connected 6LW6 for SE
As Tubelab/George has pointed out on several occasions, the 6LW6 is the big gun of sweep tubes, with a 40W plate dissipation. I have some of these in several flavors, and want to try them triode-connected as a stand-in for 300Bs. I have some 3K Hashimoto transformers coming that I want to try with these before springing for anything more expensive. I know that George has tried the 6LW6 in triode mode with a Simple SE, but does anyone have a real idea of their plate resistance triode connected?
Old 5th July 2011, 01:07 PM   #2
tubelab.com's Avatar
I never tried to measure the plate resistance, but it is pretty low. I was experimenting with cathode follower output stages and the 6LW6 will operate with the lowest voltage across the tube, in the order of 50 to 75 volts with cathode currents in the 200+ mA range. It even beat the usual triode voltage regulator tubes in this application. The circuit used the "augmented cathode follower" design so the voltage across the follower tube remained constant.
Beware there are several different constructions of 6LW6. They don't all work the same. There are versions without heat radiating fins welded to the plates and at least 3 different types with different fins. The biggest can dissipate 80+ watts with no glow.
The screen grid rating is 275 volts. Some tubes will work OK at 400 volts in triode, and some will run away at 350. Test carefully before leaving the amp unattended if pushing the envelope on voltage. A triode connected tube still looks like a pentode at idle.
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Old 5th July 2011, 05:10 PM   #3
wrenchone's Avatar
Right now, I have mostly GE and Sylvania, with one monster made in Japan, with a larger plate structure than the other two.
Curves for Triode Connected 6EW6 wrenchone Tubes / Valves 0 15th March 2010 12:52 AM
Triode Connected 6BK5 wrenchone Tubes / Valves 2 5th February 2009 03:59 PM
Max B+ for triode-connected KT88 SpreadSpectrum Tubes / Valves 32 5th December 2007 04:08 PM
Measuring Triode-Connected Pentode Curves rdf Tubes / Valves 23 11th April 2006 09:29 PM
Triode connected SV6550C with 500V HT sajti Tubes / Valves 9 18th May 2005 07:12 PM
Page generated in 0.07464 seconds (67.73% PHP - 32.27% MySQL) with 10 queries
