diyAudio Sponsor
Old 4th July 2011, 05:04 AM   #1
radio is offline radio  Macedonia
radio's Avatar
Default ECC82 JJ Made in Slovak Republic!?
Hello,
Is anyone has experience with this Tube ECC82 JJ Made in Slovak Republic.
What characteristics have since I want to create an preamplifier with it?
thanks
Old 4th July 2011, 09:04 PM   #2
denny9167's Avatar
Originally Posted by radio View Post
Hello,
thanks
I haven't used the JJ 12AU7,but I have used the JJ 12AX7 in a Dynaco FM-3 tuner,overall a very well sounding tube.
Old 5th July 2011, 04:50 AM   #3
radio's Avatar
Thanks for your reply!
expect more posts?!
Old 5th July 2011, 05:18 AM   #4
http://www.jj-electronic.com/pdf/ECC%2082.pdf
Old 5th July 2011, 06:07 AM   #5
radio's Avatar
Originally Posted by artosalo View Post
Question: Is it a good preamplifier can do with this tube ECC82 (12UX7)?
If is yes, please tell your schematic (circuit)!
thanks
Old 5th July 2011, 08:03 AM   #6
Absolutely a good pre amplifier can be built with ECC82.
A good pre amplifier is a question of good design more than what type of tube is used.
Tell us first what is your specification for the pre amplifier.
(input level, gain, output impedance required, max. distortion at nominal output level etc.)
Old 5th July 2011, 08:19 AM   #7
Gobble is offline Gobble  India
Hello,
thanks
I have these tubes .. used it with a chinese clone of grounded Grid for about a year. I preferred the Shugangs over these, then the Mullards despite their darkish sound for the imaging focus. They are a bit bloomy and not ultra low noise I think, but it may sound different in a different circuit. The shugangs are quieter.
I can't hear if they are less linear than a 6DJ8 or other tubes like maybe 6SN7 rated highly for preamps, but I strongly suspected they are not going by the sound signatures I got with various tubes including Telefunkens, BEL, FunkWerks amongst others.
Old 5th July 2011, 08:42 AM   #8
Don't worry. Nobody can hear it.
Distortion meter or spectrum analyzer is required to observe such feature.
Old 5th July 2011, 11:21 AM   #9
radio's Avatar
CD or Tuner input (input resistance 22 ... 47k) specified in Article impedance around 200 ... 600 om - in audio amplifier with the input resistance of P1 = 22 ... 47k.
Valv/Tube in the preamplifier circuit according to your choice?
To give the real sound of Tube (Steam dominant harmonic second-largest harmnik?)
Thank you in advance
Old 5th July 2011, 03:03 PM   #10
Try this.
ECC82 BJK Tubes / Valves 6 24th April 2006 02:51 AM
hi from The Czech Republic kubac Introductions 2 8th February 2004 08:41 PM
KT88SE with ECC82 sith Tubes / Valves 16 5th January 2004 01:24 AM
ECC82 with GC sith Chip Amps 0 20th November 2003 06:01 PM
Aluminium and capacitors in Czech Republic xsnailx Solid State 0 27th February 2003 07:24 PM
Page generated in 0.11435 seconds (79.39% PHP - 20.61% MySQL) with 11 queries
