diyAudio Sponsor
Old 3rd July 2011, 04:14 PM   #1
Default Polycarbonate as coupling caps?
I dug up a pair of ERO MKC capacitors, with the correct values, for an amplifier I am considering building.
I am NOT familiar with polycarbonate, nor have I ever used it before.
Are there any opinions. pro and con, as to the use of polycarbonate?
THANKS and y'all have a great 4th of July!
Steve
Old 3rd July 2011, 04:21 PM   #2
jlsem is offline jlsem  United States
jlsem's Avatar
It's one of many suitable polymers for coupling caps. There was probably a time in recent audiophile history when it was considered a ne plus ultra upgrade.
John
Old 3rd July 2011, 04:35 PM   #3
the_manta's Avatar
MKC-Caps are among the best considering temperature drift. But dielectric absorption is worse than MKP. But in the AF Range this is completely regardless. There are much, really much worse dielectrics like paper in oil, wax etc.
There is no problem using these MKC's. They'll work fine.
Old 3rd July 2011, 04:40 PM   #4
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally Posted by KrankKall View Post
ERO MKC capacitors
size advantage (and cheap nowadays)
Looks like Sponge Bob has killed another thread.
Old 3rd July 2011, 04:44 PM   #5
Thanks everyone for the information, it is greatly appreciated!
Steve
Old 3rd July 2011, 04:51 PM   #6
piano3 is offline piano3  United Kingdom
Is it true what is said about caps with polar dielectrics working best with a relatively high DC voltage across them?
Old 3rd July 2011, 05:16 PM   #7
the polycarbonate film of the type used for capacitor production became obsolete (they for whatever reason stopped making it).
As a result polycarbonate capacitors became obsolete. They were among the best available at reasonable cost. Far cheaper than Polypropylene at that time (80's to 90's) and yet almost as good. Far better than any of the MKT and MKS that have been used since.
I would not be surprised to hear that a few specialist cap manufacturers are still making polycarbonate capacitors but using old stock film or unsuitable film for current production. Be careful buying "new" polycarbonate capacitors.
regards Andrew T.
Old 4th July 2011, 03:26 AM   #8
jlsem's Avatar
Polycarbonate has been largely replaced by polyphenylene sulfide which has the same operating temperature range but lower dissipation factor and higher insulation resistance.
John
Old 4th July 2011, 03:59 AM   #9
jackinnj's Avatar
John
Polyphenylene sulfide caps are available as surface mount. You can stack a bunch of 'em and get 10u in a wee bit of real estate.
Polycarbonates are great for timing and sample/hold.
The late Bob Pease had a great cap treatise which is on National Semi's website.
Old 4th July 2011, 08:04 AM   #10
richwalters's Avatar
Pure and simple.......Environmental reasons. However all this environmental protection stuff is a hyprocrisy as Tants continue to be used by the million in mobile phones....
Note of caution.....I recently repaired a tube amp which had a polycarbonate cap across the mains input and oozed.....NO!! they aren't reliable in this application. polycarbonate caps aren't suitable as X rated.
richy
Polycarbonate obsolete? bremen nacht Parts 1 19th August 2005 05:22 PM
Polycarbonate caps to cease production Pbassred Parts 6 2nd May 2005 08:03 PM
coupling caps el capitan83 Tubes / Valves 10 17th December 2004 04:25 PM
coupling caps??? AudioGeek Tubes / Valves 14 16th September 2004 12:05 PM
What value for the coupling caps? roibm Parts 12 23rd March 2004 05:58 PM
Page generated in 0.09765 seconds (81.43% PHP - 18.57% MySQL) with 11 queries
