| diyAudio Sponsor | ||
I have a dac based on a PCM1794 and uses 25ohm for the passive i/v conversion. So thats like 200mv (not sure if that means its 400mv when converted to SE). I wanted to try the new unbalancer but its out of my budget if i have to use $15 a pop tubes. Could i use the cheaper 6n6p if i just bypass the regulated heater supply? I know that a regulated supply meant for 200ma-300ma heaters is not going to like the 6n6p's.
They have a gain of 30 and im shooting for at least 1.4vrms output. Would this work or can you help me out with some cheaper pickins? |
| tubecad and tubecad se | Nikon1975 | Tubes / Valves | 7 | 26th January 2010 06:56 PM |
| Help me pick up some good tubes! Urgent! | Andypairo | Tubes / Valves | 5 | 26th May 2006 12:11 PM |
| tubecad is back | reinhard | Tubes / Valves | 7 | 17th November 2004 04:55 AM |
| TubeCAD | Le Basseur | Tubes / Valves | 0 | 14th May 2004 07:43 PM |
| Tubecad is back up and running | jackinnj | Tubes / Valves | 0 | 3rd December 2002 10:29 PM |
| Page generated in 0.06421 seconds (67.65% PHP - 32.35% MySQL) with 10 queries |
