diyAudio Sponsor
Old 3rd July 2011, 10:29 AM   #1
h00hbt's Avatar
Default OPT for EL34
Hi all
Im planning my next project and have a spare pair of UL PP OPTīs. Im not sure they could be used for EL34 tubes, or could they?
Here are the specīs:
NOMINAL POWER rms 40 WATTS
PRIMARY IMPEDANCE 4000 OHMS
SECONDARY IMPEDANCE 4 8 OHMS
PRIMARY INDUCTANCE 35 Hy.
PRIMARY RESISTANCE 60 OHMS
FREQUENCY RESPONSE 3Hz/80K -3db
GRID 40%
Cheers
/H
Old 3rd July 2011, 11:27 AM   #2
VVT Transfomers Ltd have these.....
VTP13308 range
EL34.
6CA7.
Sub-Woofer.
RMS Power 25 Watts at 3Hz (Three Hertz).
Primary Ra-a 3500 ohms.
UL taps at 43%.
Output 8 ohms.
Optimised for Low Frequency Response.
So yours should be OK. Whether modern EL34's will stand 40 watts output is another matter.
Old 5th July 2011, 03:55 AM   #3
Specs are absolutely fine for push pull EL34.
That Primary Inductance is a little low so they are best driven from as low a source impedance as possible. That means use them in Triode Mode (around 18 Watts out) or Ultralinear Mode (just under 40W out). They would probably be a bit bass weak in pure Pentode Mode regardless of that -3dB at 3Hz spec. In fact I simply don't believe that spec. unless it is at 1 Watt level and not full output power.
Ian
Old 5th July 2011, 08:19 AM   #4
richwalters's Avatar
-3dB 3Hz..... at 25W ? Fantastic sales swallow and this is a "peak" selling spec of just possible with core on verge of saturation and must be a 12kg specimen; Sure way in quoting "optimised for low frequency response" by being reckless with the vacuum impregnation..and ruining the interwinding capacitances.
Your'e not going to find an LS that can shift that amount of LF air in ones pants. Depending on the circuit, all one will hear is alot of intermodulation of the other higher frequency notes that is with the signal, which is very undesirable.
The upper frequency response isn't quoted, that is far more interesting to the actual design of the transformer......esp when has gone to the trouble of paying for alot of weight.
Build the design, but expect a tranny half that size to sound better.
QUOTE; "Whether modern EL34's will stand 40W is another matter" ?
My old Linear Concord (1965 or so) with EL34's gave 50W o/p with 450V B+. Modern ones should easily take this.
richy
Old 5th July 2011, 10:44 AM   #5
Ty_Bower's Avatar
How about Eminent Tech's rotary woofer? Of course, you'd need some pretty large pants...
Have I fried an OPT? theskintman Tubelab 3 10th January 2011 10:09 PM
El34 PP Vs. El34 PSE alexmoose Tubes / Valves 47 6th September 2006 05:44 PM
Choosing the best EL34 pp opt barfind Tubes / Valves 17 16th September 2005 01:11 AM
FS: PAIR Vintage 50s Gardners EL34 PP OPT Double C-Core raychak Swap Meet 2 10th July 2005 06:24 AM
Page generated in 0.10720 seconds (66.46% PHP - 33.54% MySQL) with 10 queries
Copyright Đ1999-2012 diyAudio
