diyAudio Sponsor
Old 2nd July 2011, 04:49 PM   #1
Angry musical fidelity x10d clone
i have just bought off ebay a musical fidelity x10d clone buffer preamp from min9988 the picture shows russian tubes and elna capacitors imagine my suprise when it turned up today with chinese tubes second hand wima capacitors and jamiCON electrolytics and being a totaly different item alltogether i have contacted this seller and his response is it sounds ok to him so could not see the problem, i can if i buy a bently i don't expect a skoda so anyone out there thinking of getting a buffer of ebay keep clear of this seller
Old 2nd July 2011, 05:19 PM   #2
HollowState's Avatar
You should take action through eBay when you receive a different item then auctioned. And leave them a negative FB. The seller cannot give you a negative in retaliation. And his rating is bad. Learn to stay away from any seller with less then a 99.5% rating unless you have a gambling problem. Especially in China!
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University
Old 2nd July 2011, 10:55 PM   #3
most of the chinese sellers on ebay are very good and mostly helpfull i think i may have fallen foul of one rogue
musical fidelity x10d schematic arvin Tubes / Valves 45 31st August 2011 09:50 AM
Musical Fidelity A1 (2008) power amp clone project panson_hk Solid State 16 24th June 2010 04:08 PM
Musical Fidelity x10d schematics here JDowland Digital Source 8 18th February 2008 09:21 PM
Musical Fidelity- Do you know it well? SugarMedia Solid State 2 26th February 2005 01:11 AM
Using a Musical Fidelity X10D as a Valve Buffer. Shoog Chip Amps 0 22nd September 2003 07:44 PM
Page generated in 0.07966 seconds (71.05% PHP - 28.95% MySQL) with 10 queries
