Pentode cathode follower with regulated screen voltage? - diyAudio
Old 19th August 2003, 06:30 PM   #1
G is offline G  United States
G's Avatar
Default Pentode cathode follower with regulated screen voltage?
Hi All,
I'm still exploring possibilities as far as a line stage goes. I started looking at cathode followers (since I don't really need any gain) to use as a buffer/volume control after my cd player. I came across a diagram of a proposed cathode follower using a pentode (6V6 is what I have in mind) but the screen 2 voltage is regulated (?) using a triode cathode follower (5687, I have lots of them)and taking the voltage off the Rk of the triode. I'm not ashamed to say that I'm not all that familiar with biasing cathode followers and this just makes the picture a little more fuzzy. I can do a little reading up and calculating but does the potential of this circuit justify the added complexity and work? Thanks.
Gavin
Old 19th August 2003, 06:33 PM   #2
SY's Avatar
This looks wrong. In a proper pentode CF, the screen grid is held at a constant potential with respect to the cathode.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 19th August 2003, 06:48 PM   #3
G's Avatar
Hi Sy. It is held at a constant potential. The reference is the triodes cathode though. I just don't see the advantage of that though. The article can be found here:
http://www.glass-ware.com/tubecircui...llowers_2.html
Gavin
Old 19th August 2003, 07:41 PM   #4
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Yes, it is held at a constant potential but you gain the same effect (minus 300 ohms or so series resistance due to the CF) by connecting screen to B+. And that means the pentode is in triode mode. To be in pentode mode, the screen must be held at a constant potential wrt. the cathode. But that's no problem, move that coupling cap from ground to cathode.
<Checks link>
Frankly, I can't believe a publication would actually say that! Their pentode is in triode, not pentode mode. All they did was give it a 1/2 B+ filtered supply.
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 19th August 2003, 07:45 PM   #5
SY's Avatar
Just goes to show that you can't trust everything you read on the 'Net. It's not a good circuit.
Old 19th August 2003, 08:57 PM   #6
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
How about using an emitter follower:
More 6158/13D3
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 19th August 2003, 10:05 PM   #7
dhaen is offline dhaen  Europe
dhaen's Avatar
Link edited to include URL reference.
Old 20th August 2003, 04:21 AM   #8
Sch3mat1c's Avatar
That'll work too. But that uses crap (aka SS).
Tim
Old 20th August 2003, 09:23 AM   #9
EC8010's Avatar
Default Smells of roses...
I'm not sure I'd have put it quite like that, but what goes on at the screen grid of a pentode is second-order.
Old 18th November 2013, 05:35 PM   #10
I've experienced a cathodyne with an EL 84 the results are excellent. You must maintain the voltage of the screen constant.
cathode follower vlljpior Tubes / Valves 6 22nd March 2005 08:50 PM
Question about direct coupling a anode follower into a cathode follower. G Tubes / Valves 45 29th July 2004 07:47 PM
cathode follower ackcheng Tubes / Valves 2 6th July 2004 04:12 PM
cathode follower olvrkrg Tubes / Valves 3 21st February 2004 10:49 PM
Setting Pentode Screen Grid Voltage dshortt9 Tubes / Valves 1 20th January 2003 12:22 AM
Copyright 1999-2017 diyAudio
