diyAudio Sponsor
Old 1st July 2011, 06:52 PM   #1
bst is offline bst  United States
bst's Avatar
Default How can I use these high-current, low-inductance chokes?
Once again, I've gone to an estate sale and come home with many large boxes of vintage electronic components (much to my wife's dismay).
In addition to tubes, power transformers, and blank chassis, this purchase yielded a large selection of chokes. Most of the chokes are different than those I'd typically use for a power supply. For example, there are several Stancor C-2685 chokes, rated at 2 amps DC, but only 35 milliHenrys. Is there a good use for chokes like these in tube amps?
The only uses which seem even remotely plausible are as filters for filament supplies, or perhaps as some sort of inrush current limiter for a power transformer. Anyone have experience with applications for these high-current chokes? Thanks in advance.
Old 1st July 2011, 06:55 PM   #2
kevinkr's Avatar
Should work quite well for CLC filter in filament supplies or you could put them on swap as there are people here who would definitely be interested.
www.kta-hifi.net
Old 1st July 2011, 07:15 PM   #3
ChrisA is offline ChrisA  United States
I'd bet the previous owner was not into building audio amps. These chokes could maybe have been use a plate loads in an oscillator or radio transmitter but not if they have a laminate steel core. If they look like 60Hz chokes then they might have been used in a KW class power supply, again for a radio frequency amp. "kilowatt" size tube amps are not uncommon in ham radio.
Old 1st July 2011, 07:25 PM   #4
Miles Prower's Avatar
No, not really. They would be useful as parafeed chokes for a MOSFET power amp, however (although they are a bit low in inductance for that if you aren't willing to sacrifice a bit of low end performance).
The only uses which seem even remotely plausible are as filters for filament supplies...
That's about it for hollow state applications, but there are lots better ways to get DC heater power for DH finals. You could either use 'em for a solid state project, or use 'em as trading fodder to get more suitable chokes for hollow state designs.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 1st July 2011, 07:41 PM   #5
frugal-phile(tm)
planet10's Avatar
If they are low DCR they might be usable in a choke filtered SS amp.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 1st July 2011, 11:54 PM   #6
hidnplayr's Avatar
Or rewind them with lots of thin wire
Real tubes have top-caps
+5V high current low noise regulator? Kuro Power Supplies 54 27th March 2011 01:00 AM
Super high current power inductor,low resistance.Digital amplifier special inductance miden Vendor's Bazaar 0 14th August 2010 09:06 AM
High current low noise linear regulator? Kuro Power Supplies 2 24th May 2010 05:32 AM
Outside the box - Low Gain High current Amp EWorkshop1708 Solid State 1 4th June 2008 09:33 PM
Inductance coupling between chokes mig-ru Tubes / Valves 0 28th May 2005 09:06 AM
Page generated in 0.09039 seconds (77.36% PHP - 22.64% MySQL) with 10 queries
