diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   anyone knows of 6 channel tube amplier ? (http://www.diyaudio.com/forums/tubes-valves/191851-6-channel-tube-amplier.html)
lduarte1973 1st July 2011 02:24 PM
anyone knows of 6 channel tube amplifier (for tri amplifying) , that delivers 150/200w at 4 ohm ?
Tom Bavis 1st July 2011 05:10 PM
At that power level, you're probably talking monoblocks. Buy six...
TheGimp 1st July 2011 05:27 PM
Is this a surround system for an amphatheater?
What is your application?
That is a lot of power for tube amps.
lduarte1973 2nd July 2011 02:42 PM
i was thinking of an hybrid , for home use
WildOne 2nd July 2011 02:47 PM
I could build you 4 150/200w mono's and 2 60/80w mono's. Tying them all together is up to you.
WO
mashaffer 2nd July 2011 10:11 PM
Do you own a forklift? :D Seriously such a beast would be heavy, expensive and require a pretty good cooling setup. For the price you would pay for that you could build more modest amplifiers and have enough money left to buy or build some speakers that don't require an arc welder for an amplifier to beat them into submission. ;)
The trick is getting a good quality 6 channel preamp. Once you do that a trio of moderate power push pull stereo power amps (6L6 class or KT88 if you want more power) mated with a nice solid state powered subwoofer or two and you should be in great shape.
Keep in mind that those "200wpc" home theater receivers out there are really more like 35-50wpc in real life. As a data point I am testing a KT88 Single Ended amp that I am building for my grand daughter with some Mark Audio CHR-70s (not all that efficient at about 84dB/w/m). The preamp that I am using to test is not even capable of pushing the amp to full output as it has insufficient gain and it gets plenty loud in our living room dining area. If I were getting the full 8 or 10 watts it is capable of I might have to leave the room for sake of my hearing. :) 30 or 40 watts should be plenty with decent speakers especially if you are running under 80Hz signals to the sub as is standard practice.
Get some vintage Altec or Klipsch speakers and the little RH84 SE amps would be plenty.
Panicos K 2nd July 2011 10:50 PM
Originally Posted by Tom Bavis (http://www.diyaudio.com/forums/tubes-valves/191851-6-channel-tube-amplier-post2625424.html#post2625424)
Or three stereo amps :)
rvrazvan 2nd July 2011 10:55 PM
6 channels of tubes? whoaaaaaaaaaaa, that's alot :)). I have tri-amping with tubes in my head also...but with 15W each channel :).
FullRangeMan 2nd July 2011 11:06 PM
Originally Posted by lduarte1973 (http://www.diyaudio.com/forums/tubes-valves/191851-6-channel-tube-amplier-post2625232.html#post2625232)
This is alot for power even for a SS multi-channel amp.
The max you will find on the market is this Ming-Da 5 channels tube amp, looks a good heat for a nice winter, output tubes are KT90.
MC-5S home theatre five channels power amplifier - Detailed info for MC-5S home theatre five channels power amplifier,power amplifier,MC-5S home theatre five channels power amplifier,MC-5S on Alibaba.com
Factory site : http://www.mei-xing.com/english
http://i00.i.aliimg.com/img/pb/129/1...126129_845.jpg
Pano 2nd July 2011 11:35 PM
6 x 150W of tube power. Yikes!! Isn't it hot enough in Lisboa already? :D
Resources saved on this page: MySQL 18.75%
