diyAudio Sponsor
Old 1st July 2011, 12:09 AM   #1
Default 6N6P SE idea
Hi all
I wanted to build a SE low wattage amp and I hear only good things about the 6N6P. Have a look at the attached schematic and tell me what you think. Any suggestions are welcomed.
The idea was to use a cathode follower parallel feed OP stage.
I understand that the tube load and the Zo are two separate things. Is this heading in the right direction assuming the Zo on the cathode is approx 80 ohms???
thanks!
Old 1st July 2011, 12:13 AM   #2
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
For the first stage you need stable voltage in cathode instead of stable current, otherwise amplification factor would be near zero.
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 1st July 2011, 12:19 AM   #3
so you are saying just replace the first CCS with a resistor?
Old 1st July 2011, 12:24 AM   #4
If the CCS was set to 20mA with a plate voltage of 140v, wouldn't it put the cathode at a stable 4 volts (approx)..??
Old 1st July 2011, 01:00 PM   #5
TheGimp is offline TheGimp  United States
TheGimp's Avatar
It woudl put it at 4 V for a bias point but it would not be stable. as soon as the input voltage changed the cathode voltage would change to compensate to insure a constant 4mA. It would be the ultimate in cathode feedback. So the anode would not change much, if at all.
Old 1st July 2011, 01:57 PM   #6
Yes, with 200 ohms. (4 V/20 mA) You can also by-pass it with large capacitor and put the CCS at the anode.
Old 1st July 2011, 02:51 PM   #7
Michael Koster's Avatar
I have a few thoughts to add:
The LL6404 doesn't seem to be designed for interstage use. There is no quiescent DC allowed; the 6404 is designed for zero-field input use where the actual voltage across the winding changes very little This transformer is meant to be inside a current feedback loop. The LL1660S would be more appropriate.
Given the correct interstage transformer, you could simply bypass your input stage cathode CCS with a capacitor. That would keep the DC current constant and allow signal amplification at ~ mu=20.
You don't give output idle current but looking at the max cathode current of 45mA I would expect quiescent at about 25mA. That would allow a cathode current swing of ~ +/- 20 mA. Your reflected output load is about 72 ohms. +/-20 mA into 72 ohms will swing about 1.44 volts Peak or about 1V RMS. Max output power is therefore about .013 watts.
A more appropriate load would allow the full driver plate swing. Assuming 2VRMS input, the driver plate swings about 40VRMS, 56V peak. Assuming the same +/- 20mA output cathode current swing, that would imply that you want a OPT primary reflected impedance of about 2800 ohms. Max output power is about .57 watts. OPT ratio needs to be about 19:1
Michael
Old 1st July 2011, 08:51 PM   #8
Hi Guys
Thanks for the input. The interstage transformer was just a place holder and hadn't been chosen properly yet.
thanks!
Old 4th July 2011, 10:41 AM   #9
Hi All
I did a redesign using a Gary Pimm active load for the output stage with both halves of the tube in parallel. It uses the low Zout of the CCS into the output transformer. Not sure what the Zout would be exactly but would be pretty low. How do you think something like this would perform?
Old 4th July 2011, 11:04 AM   #10
It is very quiet amplifier.
You have connected both grids of 6N6P as push-pull, but anodes parallel.
There is no output signal at all.
Cheap 6n6p double ended push-pull idea - thoughts? Globulator Tubes / Valves 5 22nd April 2011 08:22 PM
Plate loaded 6N6P over SRPP 6N6P any day of the week... Bas Horneman Tubes / Valves 14 26th February 2011 04:43 AM
6p14p(EL84) SE with 6n6p build jurnal rvrazvan Tubes / Valves 30 14th February 2011 10:50 AM
OTL SE - Help Wanted with Idea poynton Tubes / Valves 51 17th January 2008 06:32 PM
Page generated in 0.09729 seconds (79.47% PHP - 20.53% MySQL) with 11 queries
