diyAudio Sponsor
Old 30th June 2011, 10:44 PM   #1
wdcw is offline wdcw  Australia
Default EL84
On the datasheet I have for the EL84 is has 6.3V for the heater supply, can I run these heaters on 12v safely?
Cheers
Old 30th June 2011, 10:59 PM   #2
vinylkid58's Avatar
No!
Old 30th June 2011, 11:01 PM   #3
no they will blow up with 12v. You can run 2 el84 heaters in series with 12 volts. You can also convert the heater supply to regulated.
Old 30th June 2011, 11:28 PM   #4
Thanks for the replies,
I have two 12AX7's & two EL84's in the circuit, so if I wire the all the heaters in series, 12v heater supply should be ok.
Cheers
Old 30th June 2011, 11:43 PM   #5
chrish is offline chrish  Australia
chrish's Avatar
No, you cannot wire 'all' of the heaters in series, only the two EL84s. You would have to set a series/parallel arrangement I would think. You do know that 12AX7s can be run on 6.3 volts by wiring its heaters in parallel don't you? You could set up a 6.3 volt heater supply for to heat all of those tubes in parallel.
Old 30th June 2011, 11:54 PM   #6
Gday chrish,
Yeah I know about using 6v & wiring all the valves in parallel, I wanted to try using 12v but haven't done it before, hence the question.
I have read that 12v filament arrangements have less noise than the 6v supply due to less current, so I just wanted to test it out basically.
Cheers
Old 1st July 2011, 12:18 AM   #7
chrish's Avatar
maybe worth worrying about on small signal tubes, but I would not think it is worth the bother on power tubes.
Old 1st July 2011, 01:55 AM   #8
Poddwatt Class-A Stereo EL84 (6BQ5) Vacuum Tube Amplifier
He uses dc but its the same thing as the OP
Old 1st July 2011, 04:53 AM   #9
vinylkid58's Avatar
Sort of the next best thing if you can't do regulated.
jeff
Old 1st July 2011, 12:08 PM   #10
DF96 is offline DF96  England
If magnetic induction is a problem then there may be a grain of truth in this, but correct wiring practice (e.g. minimising loops) is much more important. Bear in mind that a 12V supply may carry twice the noise of a 6V supply, so if there is capacitive coupling you make the problem worse!
Note that if you simply wired a 6.3V heater for 12V, as you seemed to imply in your original post, then you get more current not less up to the point that the heater fails.
FS: EL84 EI Yugoslavia & EL84 Tungsram NOS Bulk radiostar Swap Meet 3 29th January 2012 08:46 AM
Which EL84 Trebla Tubes / Valves 22 7th April 2011 09:45 PM
EL84 driving EL84 SEP tweakk Tubes / Valves 22 9th March 2011 11:23 AM
5W EL84 drive EL84 SE Audio_idiot Tubes / Valves 30 19th November 2007 04:44 AM
el84 help inquisitive Tubes / Valves 14 26th March 2005 07:19 AM
Page generated in 0.10832 seconds (80.16% PHP - 19.84% MySQL) with 10 queries
