| diyAudio Sponsor | ||
Just a quick question,
Does anyone know the minimum distance that should be between 6C33C's? (The idea of one tube distance would make it ridiculous!) Regards M. Gregg
What is the sound of one hand clapping? |
#2 |
That would be about the minimum IMVLE, these tubes run extremely hot.
www.kta-hifi.net |
#3 | |
Thank's, I will work to one tube distance then..a bit more design and thought required! Regards M. Gregg
#4 |
Before I built my 6C33C SE, I did a survey on the web, I found some good info most on German sites. What I found was that a minimum is 60mm otherwise the tubes will be overheated I have 70mm between mine.
But I have also a subchassi which tubes are mounted 8-10mm under the top panel then there are larger hole for the tube which diameter is 75-80mm this together creates a chimney effect that also helps to cool the tubes further. Look at these links and you'll see what I mean. 6C33C-B SE Verstaerker von Juergen Buschmann 6C33C - PP-Amp von Ernst Roessler Good luck Anders |
#5 | |
Thank's for the links, some interesting designs. Do you have any more useful links for layout Or construction tips regards the heat in these projects? Building OTL.. ![]() lolIt would be interesting to see any pics of OTLs anyone has built...or problems they have encountered / overcome. Regards M. Gregg
What is the sound of one hand clapping? Last edited by M Gregg; 30th June 2011 at 07:48 AM. |
#6 |
OTL?!?!!??? Good luck man
#7 |
Morgan Jones "Building Valve Amplifiers" In there it discusses how the heat from tubes like the KT88 and similar is mostly thrown out 2 sides, which are the flat sides of the tube anodes. If you have the KT88s less than 4" apart then at least make sure the anode flats are to the side and not in the line running through the tubes. Good luck with your project. Alain.
Did live about 10 years in Canada Back to France since the 1st February 2007. |
#8 | |
No problems at all, as there is strong upways rising chimney effect thru the amp's case. Inner temperature stays at around +40C deg. in normal home conditions. Upper plate carrying tubes is 2 mm steel, laser cut. This plate's temperature is around +55C deg. and it participates a bit in cooling of 6C33C tube sockets. |
#9 |
A member here at Diyaudio who have built 6C33 OTL is tubetvr he tried to convince me to build an OTL but I had all the things I needed for a SE already. You can contact him he has helped me when I needed help.
Tubeamplifiers Anders |
#10 | |
Also the schematic. That’s an interesting amp you have built. Does it levitate as well.. A few questions: What is the diameter of the unit? Interesting use of the vellman timer. What are the readouts showing? Do you use the counter function as well? I guess you could program this to have a burn in function? Are the push buttons are ON /OFF retentive relays / no volt protection? I see you have also used a current limiting relay. Could you describe the start sequence? You have approx 5500F in each rail, I'm looking at 4700uF + addition 1000uF similar to Alastair E. Did you have any awkward circuit design problems ? Regards M. Gregg
What is the sound of one hand clapping? Last edited by M Gregg; 30th June 2011 at 01:10 PM. |
| 6c33c-b & 6c33c-v | skybird | Tubes / Valves | 4 | 21st April 2009 06:21 AM |
| Transformer spacing | weinstro | Tubes / Valves | 8 | 7th August 2008 05:53 PM |
| 6C33C-EB / 6C33C-EV extended life ? | ger56 | Tubes / Valves | 2 | 14th October 2007 05:54 PM |
| Spacing UcD400s? | DSP_Geek | Class D | 4 | 15th February 2007 12:57 PM |
| 3-Way Driver Spacing | 69stingray | Multi-Way | 4 | 24th June 2005 02:13 AM |
| Page generated in 0.11739 seconds (86.19% PHP - 13.81% MySQL) with 10 queries |
