| diyAudio Sponsor | ||
Hi Group:
I've been looking at data sheets for a long time. For the most part I can figure out what I need to know. But on the Genalex, Gold Line and other data sheets there are two parameters that specifies the Voltage for the Plate and Screen, Va, g2(b) and Va, g2(o). My question is what is the (b) and (o) indicate?? I've looked high and low for and explanation. http://www.westernelectric.com/produ...spec_sheet.pdf Any ideas Thanks RonL |
#2 |
No idea. (0) (i.e. zero) may mean no signal, but I don't know what (o) and (b) mean. Have you tried looking for the original GEC data sheet, not some modern rehash of it? The people who write modern valve data sheets often don't know what they are doing, as they were brought up on chips and transistors. Hence they make mistakes.
#3 |
Thanks for the reply. It seems to be on all of them:
http://www.datasheetcatalog.org/data...3/633155_1.pdf |
#4 |
OK, wild guess coming up: Va(b) could mean HT supply voltage, Va(0) means voltage at anode with no signal present (after DC drop through output transformer primary resistance). This doesn't quite seem to fit the figures they give, so don't take it as gospel. As I said, a wild guess.
#5 |
I checked a couple of the figures and your interpretation of the o is consistent- values at no signal.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#6 | |
работник
Wild guess can be confirmed as nearly correct! Here is a clip from the 1952 edition of Markus & Otte "Data and Circuits of Radio Receiver and Amplifier Valves" Book IIIa A text well worth having, for many such instances of nearly-forgotten knowledge. Last edited by Rod Coleman; 30th June 2011 at 08:35 AM. Reason: correct to 'nearly!' |
#7 | |
Va(b) was an old term for battery voltage....now anode supply volts; Ia+g2(o) = Combined anode and screen current at Zero output. Va (o) = Anode volts at Zero output. Ia+g2(max sig) = Combined anode and screen current at MAx output. richy |
| 6l6 data sheet question | grungeman91 | Tubes / Valves | 4 | 20th May 2011 11:04 AM |
| Another KT-88 | cryo | Tubes / Valves | 23 | 1st October 2008 03:06 PM |
| Mikael's KT-88 question | cryo | Tubes / Valves | 15 | 27th April 2008 07:00 AM |
| Question about KT 88 integrated | gjo | Tubes / Valves | 1 | 10th April 2006 10:17 AM |
| Need PP KT-88 amp design and KT-88 for triode use? | Norris Wilson | Tubes / Valves | 7 | 23rd February 2005 12:12 PM |
| Page generated in 0.10232 seconds (81.35% PHP - 18.65% MySQL) with 11 queries |
