| diyAudio Sponsor | ||
Good morning all...
Sorry for my poor drawing ability, but will this work? Thanks, Ray rsumperl@hhk.com
A great pleasure in life is doing what people say you cannot do. |
#2 |
What are you trying to achieve?
#3 |
The bridges feed voltage regulators, however the regulators are different from each other.
#4 |
Are you trying to regulate both positive and negative voltages?
#5 |
As drawn it will not work, unless you are trying something strange. A CT secondary should normally feed just one bridge. Tell us what you want to do, and then we can tell you how to do it.
#6 |
#7 | |
OK I read about feeding two regulators. I still can't figure why each regulators would need it's own bridge. It is better not to use a bridge because it wastes power with two diodes in series, so you have double the voltage drop in the rectifier Last edited by ChrisA; 28th June 2011 at 03:59 PM. |
#8 |
It will work as long as the two outputs are totally isolated from each other. Connect any of the output terminals to another or to a common point such as ground and you'll have a short circuit. A single bridge can give you positive and negative supplies with a center-tapped transformer.
#9 |
Banned
What is the specification of the transformer (ie 12-0-12VAC 50VA).
What voltages and currents are you trying to achieve ? |
#10 |
Let us assume for the moment that the CT is grounded. It may not be, but we have to establish some voltage reference as all voltages are with respect to some other voltage.
Then the - leg of the upper supply will sometimes be floating, sometimes be connected to the CT via a diode drop, and sometimes connected to the upper sec output via a diode drop. Conversely for the + leg. Similarly, only opposite, for the lower supply. Hence all your supplies will be whizzing up and down at line frequency. I assume this is not what is wanted - most people want a DC supply to be referenced to a fixed point (often ground). |
| Need help wiring CT transformer | huskydawg9 | Tubes / Valves | 5 | 2nd January 2010 03:04 AM |
| transformer with ct or non ct? | galih | Chip Amps | 7 | 7th December 2009 05:08 PM |
| I need a 120v ct transformer... Where to look? | ThSpeakerDude88 | Tubes / Valves | 15 | 24th March 2007 02:19 AM |
| Using a transformer without CT? | Serow | Pass Labs | 3 | 19th November 2003 09:50 PM |
| Page generated in 0.10465 seconds (80.70% PHP - 19.30% MySQL) with 11 queries |
