diyAudio Sponsor
Old 28th June 2011, 02:25 PM   #1
Troncones's Avatar
Default What should clipping look like? (AKA reading sine waves)
All of the SE amp projects I’m playing with produce a sine wave that looks like this at clip. These are typically 3 to 5 watt amps so I make an effort to get all out of them I can. It looks to me like if I could get it to be more concentric I could get just a little more power.
I have tried different plate voltages, quiescent points and NFB values with the same results. Is this as good as it gets? (Scale: 2V/Div)
The Myth: A hand full of Tubes, Caps, Resistors and Iron and you have an Amp. The Reality: You have self induced Dementia. Newbie.
Old 28th June 2011, 02:36 PM   #2
DF96 is offline DF96  England
"Concentric"? Maybe you mean symmetric? SE amps are likely to clip asymmetrically. If you want symmetric clipping then you need push-pull.
As the top and bottom peaks have different shapes it probably means that they result from different mechanisms. Most likely is onset of grid current at one end, and valve cutoff at the other end. To maximise power output you need the correct load impedance, but real loudspeakers vary so much that in reality this will not get you very far.
Old 28th June 2011, 08:06 PM   #3
Troncones's Avatar
Yes symmetric was the word I was looking for this morning.
Yes I have noticed that PP amps clip more symmetricly.
Thanks for you input.
Recovery from clipping, soft clipping hahfran Solid State 49 23rd February 2010 01:03 AM
tuning forks for pure sine waves? cuibono Everything Else 13 17th September 2008 04:39 PM
Sine Wave Generator with bulbs (Sine-lightenment) Rodeodave Everything Else 6 21st July 2008 12:19 PM
sine waves on nos dac regal Digital Source 5 11th March 2007 09:38 PM
Sine and square waves percieved pitch, why? baggystevo82 Everything Else 33 11th March 2005 04:18 AM
Page generated in 0.06420 seconds (81.06% PHP - 18.94% MySQL) with 11 queries
