| diyAudio Sponsor | ||
During more than 19 years I have 2 home-made SE-VT4C amps. Have a pair of RCA and G.E. VT4C's.
As neither of these tubes is after those years 100%, I like to replace them by a matched pair of 845B's, with kathode bias too. (And I don't dislike somewhat more output...) Because 211's and 845's are DHT's, a lot of fixed-bias parts (like 4 diodes, CRC, potmeter) are in the audio path, so I prefer kathode bias. And I dislike the weakest link: the potmeter (a bad contact causes a broken tube, as Rk is 10R). 845 kathode bias : I estimate Rk 1K5, Ia ca. 84 mA; and the by-pass cap wil be Solen/SCR 200uF/250V. MKP (as audio-proof 200V. caps/elko's are hard to find). Today the VT4C's have kathode bias (Rk 1K0, Ia 53 mA, B+ 1025V., caps: 2x 47 uF/100V. Black Gate). The HV powersupply: Sec. 800V./300mA, 4x BY228 (in 1992 I wasn't familiar with the 866A-family yet), than 1 parallel 5R4WGB ('soft-start'), than CLC (C's: 51uF/1500V. Solen/SCR MKP's, L: 15H/200mA). Hook-up wire: Kimber TCSS. The pre-drivers (2 G.E. 6SN7GTB with DC-coupling, B+ 320V.) have an independ PS. Circuits with 845 kathode bias are hard to find; found only this one. Anyone familiar with 845 tubes (valves) in kathode bias? (I am aware B+ will drop) Last edited by Dogie_Hogan; 28th June 2011 at 07:44 AM. Reason: spelling |
#2 |
Why do you want to vaste precious voltage just to heat a huge resistor
Yves. |
#3 | |
************ edit Attached: 845 data (source: "Transmitting Tubes", RCA 1938) Last edited by Dogie_Hogan; 28th June 2011 at 08:01 AM. |
#4 |
[QUOTE=Dogie_Hogan;2621808]2 reasons: fixed-bias: many parts influence the final -audio- result (kathode bias: just risistor + cap) and safety (bad contact in potm., tube drift: checking neg. supply regularly).
Actually the Fixed Bias parts are not in the Audio-path, Cathode-resistor and capacitor are! You may design the fixed-bias pot so that when you have a bad contact in the pot-meter the negative voltage increases, cutting-off the tube. Just use the pot. as the divider-resistor to ground. If it fails, the negative voltage just increases and keeps your tube safe. It is probably true that a cathode-biased system will correct for wear on tubes to some extent but I find it more usefull to just check the fixed bias once in a while. With fixed-bias you are not throwing away watts into heating a resistor. The watts should go to your speakers rgds, /tri-comp |
| Dynamic Bias - Active Bias - Automatic/Self biased - Overview wanted | tiefbassuebertr | Pass Labs | 11 | 5th May 2011 08:42 PM |
| Driving EQ from kathode resistor | b_force | Tubes / Valves | 10 | 11th January 2010 11:48 PM |
| Changing grid leak bias preamp to cathode bias | bereanbill | Tubes / Valves | 8 | 28th March 2009 05:26 PM |
| Stray hum pickup *preamp* cathode R-bias vs. battery bias & 12AU7vs.5687 | awedio | Tubes / Valves | 2 | 19th April 2008 01:30 AM |
| Supressed bias amplifier, automatic variable bias system. | destroyer X | Solid State | 2 | 20th September 2004 10:24 AM |
| Page generated in 0.07067 seconds (79.67% PHP - 20.33% MySQL) with 11 queries |
