Duelund Alexander Copper Foil Capacitors - Page 8 - diyAudio
Old 8th February 2013, 11:17 PM   #71
IslandPink, please report once you test the ZN's!
Thorsten Loesch recommend mundorf ZN's for best price/performance capacitor. :
'' Above the budget region I take Mundorf/Audyn/SCR Tinfoil types as
being "sane cost & high performance"
Old 9th February 2013, 03:42 AM   #72
popilin is offline popilin  Argentina
popilin's Avatar
It is an established scientific fact that Gold Foil - Snake Oil capacitors reduce noise and distortion to almost immeasurable levels.
Using the multipole expansion, and the addition theorem of spherical harmonics, it can be demonstrated that the noise and distortion remain only on one plate of the capacitor, due to the unique Quantum properties of Gold-Snake Oil combination.
I'm poor, and I must settle for 0.03% of the MKTs, or 0.01% of the MKPs...
I do not suffer from insanity, I enjoy every minute of it. - Edgar Allan Poe
He has the most who is most content with the least. - Diogenes of Sinope
Old 9th February 2013, 10:31 AM   #73
Dear Popilin you know how caps are build ?
caps are resistor and induttance at the same time , and this with capacity vary with frequency
you know why there are condenser microphony?
russian teflon ft2-ft3 are cheaper
no 0.01 on caps at last 1% and you will need only for RIAA
Old 9th February 2013, 05:48 PM   #74
popilin's Avatar
Neglecting edge effects, we can obtain a reasonable approximation to the value of capacitance C.
For two parallel plane plates of area A separated by a distance d, filled with a dielectric medium of dielectric constant ε, from Maxwell's equations
∇.D = 4πρ
D = ε E
Integrating in a volume V
∇.D dV = ∮D.ds = D A = ε E A = ∫4πρ dV = 4πQ
Then
E = (4πQ) / (ε A)
Also
E = - φ = dφ/dx
Integrating
Δφ = ∫dφ = E ∫dx = E d
By definition
C = Q/Δφ
Then
C = (ε A) / (4πd)
In a real capacitor, influence both, dielectric and geometry.
However, R leakage depends strongly on dielectric, and ESL on geometry.
That is why a vulgar multifoil chip capacitor, MKT or MKP, can minimize ESL and ESR.
Microphony
Valve Amplifiers - Morgan Jones - Google Libros
That is why if you use an easily compressible dielectric as teflon, Russians, cleverly placed one second rigid shield.
THD
The values ​​given were measured in laboratories of elektor magazine in the 80s.
If your ears can differentiate between 0.01% and 0.03%, good for you !
But if you tell me the super duper gold foil snake oil may exceed these levels/sound better, I would say that the amplifier design is sub optimal.
Old 9th February 2013, 06:02 PM   #75
cotdt is offline cotdt  United States
Send a message via AIM to cotdt
You can make your own film capacitors with kitchen aluminum foil and oil-soaked paper. It will sound better than some very expensive capacitors.
Old 9th February 2013, 08:55 PM   #76
And resistor from pencil HB
Old 9th February 2013, 11:18 PM   #77
popilin's Avatar
I think both extremes are bad, following this line of reasoning, we end by proposing an amplifier made from coconuts, as Gilligan's Island.
There is also the risk that someday they offer "Audio Grade HB Graphite Resistors" at astronomical prices.
Can not be denied that the quality of all the components used influences the final result.
If the difference is negligible, and even sometimes subjective, is well, and we can continue to feed the myth that money can buy everything.
If you put a super duper Gold Foil Snake Oil capacitor, and the sound improves to the point of exclaiming "wow ! that good capacitor !" check your design.
Old 10th February 2013, 01:06 AM   #78
duelund resistor I thinks .....
Not for sissies diy GRAPHITE RESISTORS
Old 10th February 2013, 01:19 AM   #79
popilin's Avatar
Amazing ! Definitely not for sissies.
Old 20th February 2013, 07:19 PM   #80
Apologies for breaking into the Duelund thread again to report on Mundorfs !
I can report the current Mundorf ZN's ( Tin/polyprop ) are proving to be excellent after about 15 -20 hrs running . This test is on the output of a phono amp at line-level signal.
They are significantly better than the old Audyn KP-SN to my ears . The tonal balance is better , sound a bit warmer than the slightly cold and bright character of the KP-SN. They have useful extra tone in the upper bass without losing anything elsewhere .
The top end is more refined without the slightly edgy character of the KP-SN .
They have excellent realism and 'immediacy' on well-recorded instruments and voices.
They seem to be overall a bit more classy and with more tonal colour in the mids, than the Audyn 'True copper' which I tested recently .
From my memory of the Mundorf silver/oils , I would say the ZN's would 'wipe the floor' with the silver/oils in bass and midrange tone, but the silver/oils might have just have a little more upper treble resolution .
Now someone needs to compare to the Duelunds !
( however whatever the result, the ZN's are an extraordinary bargain )
New unused pair Duelund VSF copper 3.9uf for crossovers qusp Swap Meet 3 11th March 2010 02:42 PM
Copper Foil a.wayne Planars & Exotics 4 23rd February 2010 11:08 PM
FS: New Pair Duelund VSF Copper foil Cast Caps 0.22uf/630v texaslonghorn Swap Meet 4 17th February 2010 01:29 AM
Copper foil around electrolytic capacitors? wreeve Digital Source 86 21st October 2005 10:23 PM
copper foil inductors dave k Multi-Way 1 1st June 2003 01:02 AM
Copyright 1999-2017 diyAudio
