| diyAudio Sponsor | ||
Hello all,
I am currently experimenting with using a tube buffer (simple cathode follower) instead of the opamps based preamp section in my integrated amplifier. Anyway, I was wondering how to calculate the maximum voltage swing (I know gain is slightly less then unity) in the schematic attached. The reason I'm asking is because I plan on using Vg=-2V (@ 20 mA) and my sources are about 2V rms. I am using 6N6P tube. Thanks. Ronald Last edited by tingtong5; 23rd June 2011 at 01:13 PM. |
#2 |
I do use a grid stopper resistor of 1K2 by the way and also a 56R resistor from cathode to output capacitor. Both are not drawn in the schematic but also irrelevant I guess for calculating max voltage swing.
I plan on using B+=200V, Rl=5K and Rb=100R to get the -2V @ 20 mA operating point of the 6N6P. Rg= 1M. |
#3 |
here is the formulas that govern you circuit:
common-cathode stage, unbypassed cathode: ![]() Voltage Gain (Output 1): Av = (mu * Rp)/(Rp + ra + (mu + 1)*Rk)Input impedance:Rin = RgOutput impedance (Output 1):Rout = [(ra + (mu + 1)*Rk) * Rp] / [(ra + (mu + 1)*Rk) + Rp]Output impedance (Output 2):Rout = [(Ra + ra)/(mu + 1) * Rk] / [(Ra + ra)/(mu + 1) + Rk]Frequency response (Output 1):f1 = 1/(2*pi*Ci*Rg) - highpass breakpoint due to Ci/Rg f2 = 1/(2*pi*Co*(Rout + Rl)) - highpass breakpoint due to Co/Rout/RlWhere: Note that Rl is ignored in the output impedance calcuations for output 1, not because it doesn't affect output impedance of the overall circuit, but because output impedance is traditionally the impedance of the output of that gain stage looking back into the output. Rl is the input impedance of the following stage, so it is not included. Of course, when calculating overall gain in an amplifier, the loading effect of Rl must be taken into account. In the case of the output taken from the cathode, Rl must be included because it will affect the impedance seen looking back into the cathode. Last edited by DavesNotHere; 23rd June 2011 at 04:27 PM. |
#4 |
Thank you Dave, however it still does not answer my question what the maximum (undistorted) voltage output will be...
#5 |
Undistorted is zero. You should use plate curves and find an optimal regime according to load impedance.
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#6 | |
But I think I suddenly do get it... Follow the loadline to Vg=0 and then read the voltage on the x-axis and substract it from the voltage at the operating point, which gives half the voltage swing. Is this correct? |
#7 |
Yes. Loadline will show you both maximal positive and negative swing for given distortions.
#8 | |
Cheers Ian
Ian |
#9 |
Ian, you probably forgot that it is about cathode follower: it's bootstrapped, so grid-cathode variations are greatly reduced in respect to input voltage variations. They can be seen from the same plate curves.
#10 | |
In which case, as you say load lines rule the day, with the proviso that the ac load is the important one. Cheers Ian
Ian |
| Heater to Cathode max voltage specs, including signal swings? | flysig | Tubes / Valves | 2 | 28th June 2009 09:22 PM |
| How can I calculate voltage over cathode resistor? | Nordic | Tubes / Valves | 27 | 30th April 2008 10:44 AM |
| How to calculate for cathode follower | aardvarkash10 | Tubes / Valves | 3 | 8th August 2007 10:58 AM |
| Pentode cathode follower with regulated screen voltage? | G | Tubes / Valves | 8 | 20th August 2003 08:23 AM |
| Page generated in 0.10627 seconds (80.52% PHP - 19.48% MySQL) with 11 queries |
