| diyAudio Sponsor | ||
Are there any type 26 driver SE (45, 2A3 or 300B) power amps? The only way I find the 26 used is in a line amp.
#2 |
Frank: The search button is your friend....
26 Driver Tube for 45 - Operating Points Back at the 45 SET One of the posts refers to Gary Pimm's 26 driven parafeed 45 amp, but the link is broken...... DHT drivers - shootout Looking for 300B or 2A3 design suggestions......gearing up for a new project |
#3 |
Hi!
I built a 26 / 35 amp, see links below. Actually the driver can be configured for either 26 or 10Y type tubes. Output is switchable between 45 and 2A3 VinylSavor: Making of an 45 / 2A3 amplifier The PSU: VinylSavor: Making of a 45 / 2A3 amplifier, Part 2 - The PSU Best regards Thomas
http://vinylsavor.blogspot.com/ |
#4 |
My main amp is a 27 driving a 71A, direct coupled. Sound is probably very similar to a 26 / 45 amp, which is to say magnificent! So I say go for it.
#5 |
boywonder.
You not only help to get me out of trouble, you help to get me into trouble as well. The information you've listed is over a hundred pages of serious reading. If the participants could only come to a conclusion as to what is best, I wouldn't have so many decisions to make. I see you have your own plans to work on. Thanks to everyone for the inputs. Frank |
#6 |
quote:
My main amp is a 27 driving a 71A, direct coupled. Sound is probably very similar to a 26 / 45 amp, which is to say magnificent! So I say go for it. Heck I'd love to see the schematic on the 27/45 There are many talented people on this forum maybe someone will draw up something for the 26/45 quest. |
#7 | |
Hi!
For a 45 a 27 or 26 will not provide enough gain to reach the usual sensitivities. Either a preamp with enough gain is required or a input transformer with step up. Check out the schematic of my 46 amp: VinylSavor: Single Ended Amplifier Concept, Part 7 Can be adapted for 45 as output tube. A 27 would fit in nicely, but note my remarks about gain above. Best regards ... Thomas
| Looking for simple Schematic of 2A3 or 45 or 26 Headphone Amp SE OTL ? anyone ? | calico88 | Tubes / Valves | 47 | 13th March 2011 03:08 AM |
| 10Y, 26, 27 and 45: relative microphonics | rick57 | Tubes / Valves | 38 | 30th December 2010 11:38 PM |
| 26 Driver Tube for 45 - Operating Points | eeyore | Tubes / Valves | 20 | 30th December 2010 08:21 AM |
| SE amp using 1619 instead of 45 triode | rcavictim | Tubes / Valves | 9 | 12th November 2005 06:50 PM |
| 26/45 Choice help needed | walk | Tubes / Valves | 1 | 5th September 2002 11:13 PM |
| Page generated in 0.08225 seconds (80.70% PHP - 19.30% MySQL) with 10 queries |
