diyAudio Sponsor
Old 22nd June 2011, 08:50 AM   #1
markusA is offline markusA  Sweden
Default Help me find cirquit, I forgot where I last saw it?
I'm looking for a DC coupled cathode follower (I think it was a cathode follower?) with a servo on the cathode side fixing the output at dc ground.
I think I've seen it posted somewhere as cirquit of the week or something like it?
It's possible that it wasn't a cathode follower, my memory sometimes plays tricks on me. (I had a computer crash and all my bookmarks got lost.)
Any help is appreciated.
Old 22nd June 2011, 02:40 PM   #2
smoking-amp's Avatar
Maybe something like this? The right side LTP (V3,V4) acts to boost the gm of the right side (V2)power triode. This was in the old anti-triode SET emulation threads. There was an RIAA phono stage circuit around too that used a gm booster, I think with just one add-on tube.
Ohms Law V = I R
Old 22nd June 2011, 03:41 PM   #3
leadbelly's Avatar
Well DC coupling both the input AND output of a CF would be quite the trick now
Your idea that was a "circuit of the week" suggests the Tubecad site. I would just google "site:www.tubecad.com servo" and see what you find.
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 22nd June 2011, 05:10 PM   #4
Thanks for reminding me. I found a circuit of the month that's quite interesting.
Old 22nd June 2011, 05:19 PM   #5
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
It is easy, with 6N7 for example.
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 22nd June 2011, 05:20 PM   #6
"I found a circuit of the month that's quite interesting."
Link?
Ohms Law V = I R
Old 22nd June 2011, 05:22 PM   #7
Circuit of the Month: October 1998
Old 22nd June 2011, 05:48 PM   #8
leadbelly's Avatar
I assume you mean it's easy using multiple sections, but only one of those sections is the actual CF.
Old 22nd June 2011, 05:52 PM   #9
Wavebourn's Avatar
No, I assume similarly to what was shown in Broskie's article, but no need for additional voltage drop resistor in cathode. Just a CCS in cathode with servo.
Even without CCS and servo (that is gyrator actually), load 6N7 on a choke with low DCR, that's it.
Old 22nd June 2011, 06:00 PM   #10
leadbelly's Avatar
If there's no resistor then what's setting the bias?
Speaker Design... but forgot the name TubeManiac Full Range 1 22nd May 2011 01:37 PM
I forgot what soft ware I used can someone help please? Boscoe Software Tools 3 22nd May 2010 07:00 AM
The Super Hiper Highly Ultimated electronic component... and you forgot it destroyer X Solid State 6 3rd August 2006 07:48 AM
I am so old I forgot my question, please do not respond ststone Everything Else 0 11th December 2002 04:04 AM
How rude - Forgot to introduce myself! Rarkov Introductions 0 30th September 2002 10:37 AM
Page generated in 0.09574 seconds (77.05% PHP - 22.95% MySQL) with 11 queries
