diyAudio Sponsor
Old 22nd June 2011, 02:14 AM   #1
rhone is offline rhone  Australia
Default Plate resistor for FVP5a
Hi all,
A quick question. I plan on building the line-stage part of Allen Wright's FVP5A pre-amp.
The schematic specifies a 25K ww as the plate load for the 6922 gain stage part. I'm guessing a 2W-5W part would be suitable. Now I can't find that exact value so what should I do?
Use a Mills 27k 5W? Series connect two smaller Mils? Parallel two 47k or 51k resistors? Or something else?
In general is there any problem using resistor combinations as plate loads?
Thanks,
Rod
Old 22nd June 2011, 02:20 AM   #2
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
two 51K
no general problem
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Plate load resistor question Carlp Tubes / Valves 14 21st January 2008 01:41 PM
Plate Resistor philipbarrett Tubes / Valves 4 25th March 2005 01:48 PM
plate resistor, input lead vlljpior Tubes / Valves 7 23rd January 2005 11:06 AM
screen-plate resistor and grid leak resistor metebalci Tubes / Valves 4 26th February 2004 03:18 AM
Vacuum State Electronics FVP5A runeight Tubes / Valves 28 5th December 2003 10:46 AM
Page generated in 0.06214 seconds (67.64% PHP - 32.36% MySQL) with 10 queries
