Help with plate chokes
Old 11th September 2003, 12:44 AM   #31
316a is offline 316a  England
316a's Avatar
Default Ears
Originally posted by dhaen
However, that should not stop us from experimenting. Great things come from trying ideas, and learning.
Don't forget also, that we have differing expectations. What's acceptable to one, is not to all.
If it sounds good to the experimenter then so be it , if it measures crap but still sounds good ditto . We all have our standards . Personally I have also had very poor results with HT chokes as anode chokes (oil-filled c-cores) , the midrange was there but little else but don't let my opinions put anyone off . Probably better off using higher HT and a current source instead . However I have had promising results using mains toroids as centre-tapped push-pull chokes which I feel are worth persuing further . One thing I can suggest is that those with less revealing (warm'n'woolly) speakers are not going to notice the difference so it's not going to matter !
316a
Old 11th September 2003, 12:58 AM   #32
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Nor are any other suggested mods, IMO.
Frank
Old 11th September 2003, 01:01 AM   #33
316a's Avatar
Default Woolly
Probably correct .
316a
Help with plate chokesHide this!Advertise here!
UTC CG-52AX - use as plate chokes? rongon Tubes / Valves 3 22nd August 2009 07:11 AM
Magnequest EXO-99 600H/150H Plate Load Chokes cm7 Swap Meet 6 18th July 2009 01:54 AM
Plate chokes & Power chokes JC951t Tubes / Valves 3 19th October 2006 03:18 PM
Subwoofer Plate Amplifier Base Plate supplier? jwells777 Parts 1 11th May 2003 07:40 AM
