diyAudio Sponsor
Old 20th June 2011, 07:56 PM   #1
Default why does my amp require a preamp?
i just acquired a vitage luxman mq70 and the thing i notice is that amp sounds better by raising the volume while maintaining the same absolute volume through source (pc). the sound just becomes more dynamic and the bass better defined. am i imagining things or are some amps designed that it's meant to sound best on maximum volume?
the amp has double volume pots in the back that's click operated instead of smooth attenuation. there are only ten 'steps' of volume and the amp was initially sold with a matching preamp, i read.
Old 20th June 2011, 08:30 PM   #2
Ideally you want your pc out pegged so you get full dac resolution.
Old 20th June 2011, 08:31 PM   #3
Tinkerer
I am sure you are not imagining things, but i would guess that it has more to do with your PC sound card (output impedance) and less with the power amp. If possible give it a try with a CD/DVD player with variable output volume maybe?
Old 20th June 2011, 08:44 PM   #4
FullRangeMan's Avatar
Maybe you already know this:
If you use a CD player and your power amp have a input stage, you not need a preamp, unless for easy volume control.
Some passive integrated tube amps had just a pot volume control and a input selector, as some PrimeLuna/Mystere amps and various chinese brands.
It is a proven good sound topology, less parts = more quality.
The SS integrated amps Bryston B100 and Pass INT150, had a preamp stage, but do not had a input stage on the power amp.
A separate preamp box is a oldfashioned unnecessary equip., a heritage from the low level mili-volts signal vinyl era, if you run a 2Volts CD player, you not need a preamp separate.
You may just use a passive integrated amp, or just add a suited volume pot in the amp front input.
>Never go to a psychiatrist, adopt a cat or dog from the streets. On the streets pets live only two years average.
Old 20th June 2011, 08:58 PM   #5
nigelwright7557's Avatar
I use an MP3 player without a preamp and it sounds very good.
However if I want full power out of my amp I need a preamp.
The fewer stages of amplification the better.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 21st June 2011, 03:06 AM   #6
oops i should have said my source as DAC. i'm controlling the volume through foobar but it's to teralink reclocker>dac>amp
I require a DAC HimeshP Digital Line Level 6 30th December 2010 11:54 AM
Do I really require this box volume? rhythmdiy Multi-Way 6 4th November 2008 04:25 AM
Require Instrument Samples neutral Music 3 8th November 2005 09:13 PM
Would this require degaussing? ewan Everything Else 4 5th December 2003 10:59 AM
Page generated in 0.09464 seconds (74.15% PHP - 25.85% MySQL) with 10 queries
