| diyAudio Sponsor | ||
i'm sorry if i'm making one too many threads about these issues (perhaps i'm the one with the 'issue') but i am chemically sensitive and this website is the only place i can think of where to get info.
right, my newly acquired fisher 400 is emitting a rather pleasant odor. it's coming from the little phenolic boards to the side where some caps n resistors meet. i recognize this as 'that old amp smell' but would like to know in detail just what the board could be off-gassing. the odor is flowery with a tiny hint of gasoline-like oil smell. |
#2 |
Speakerholic
Eau d'aromes ozone with a puff of magic smoke and a hint of violet voltage?
Just guessing. |
#3 |
phenols (and phenolic resin derived from chemical transformation of phenols) are common biological compounds. Some neurotransmitters and some compounds evolved in the taste and odour of food. If I am not mistaken phenolic resins were used in PCBs before fiberglass was used.
I suppose localised heat is causing decomposition of the phenolic resin in close proximity of the heatsource. This may be responsible for the smell you perceive. In some old automotive applications phenolic resins were used for brake pads. The bondinng material would give off some similar odour when thermically stressed. |
#4 |
do you think formaldehyde is still present after half a century or is it just the resin itself that im smelling? because i gotta say, it actually does smell good.
| Fisher 500C Receiver $400 Walnut Cabinet, New Output Tubes | Scott Novak | Swap Meet | 1 | 16th August 2009 07:16 PM |
| Fisher 400 Tube Tuner/Amp fpr Sale (in Europe) | LinuksGuru | Swap Meet | 3 | 14th December 2008 07:49 PM |
| Fisher 400 Output Transformers | wrenchone | Tubes / Valves | 6 | 7th November 2008 03:52 AM |
| fisher 400 tweaking issues | grahamrunsran | Tubes / Valves | 1 | 26th September 2008 11:32 AM |
| Fisher 400 questions | pageboy | Tubes / Valves | 19 | 16th May 2008 02:44 AM |
| Page generated in 0.07392 seconds (71.41% PHP - 28.59% MySQL) with 10 queries |
