EL84 DPP and Full Range problem - diyAudio
Old 17th August 2003, 09:01 AM   #1
PTSOUNDLAB's Avatar
Default EL84 DPP and Full Range problem
Hello,
I have a problem with a EL84 28W DPP amplifier and a Fostex FE206E loudspeaker. The FE206E is a full range driver with no filter mounted on open baffle (just a capacitor for protection).
After 1 or 2 minutes of working, the FE206 begins vibrating of front behind. There is a sort of buzz and the FE206 move forwards and towards the back.
The volume is minimum. If I connect the FE206 on 8 ohms taps, the problem appears almost immediately, if i connect the FE206 on 4 ohms taps where there is feed back (contre réaction in french) the problem appears after 1 or 2 minutes.
FE206E are 8 ohms speakers.
Do you have an idea of what is the problem ? personally I am not certain if it's a problem of impedance or capacitor or resistor or valve. I don't think it's valve problem.
Thank you all.
Pascal.
Old 17th August 2003, 09:13 AM   #2
PTSOUNDLAB's Avatar
Default schematic
Hello,
the schematic of the amplifier with psu is at:
http://ptsoundlab.free.fr/sectubes/s...comp28el84.jpg
Pascal.
Old 17th August 2003, 09:53 AM   #3
SHiFTY is offline SHiFTY  New Zealand
SHiFTY's Avatar
Could be "motorboating"... are your coupling capacitors much bigger than 0.1uF? Sometimes, if they are too big, the power supply will oscillate through the amp at low frequencies.
Old 17th August 2003, 10:03 AM   #4
PTSOUNDLAB's Avatar
Default coupling cap
Hello,
If you talk about PSU capacitors, I have try without coupling capacitor and with 0,1µF 400V capacitors (parallel). The problem is the same. The channel is like the schematic.
Cordialement.
Pascal.
Old 17th August 2003, 11:18 AM   #5
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
The first stage of the ECC83 doesn't seem to have a grid-leak resistor to ground. Add a 1M resistor, and see if it makes any difference, even if it doesn't, you need this resistor.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 18th August 2003, 08:22 AM   #6
I once had the same problem with a rebuilt Leak Stereo 20. The culprit turned out to be oversized cathode decoupling capacitors. Try reducing the 470uF to 100uF.
Old 18th August 2003, 06:23 PM   #7
PTSOUNDLAB's Avatar
Default Thank You
Thank you boys, i will try.
Pascal.
full-range speaker problem nandax Full Range 0 9th December 2008 07:30 AM
Frequency range of the human voice & full range center channel speakers jwmbro Multi-Way 31 20th January 2008 03:07 PM
$200 pair full range drivers for PP EL84? ihscoutlvr74 Multi-Way 0 24th December 2007 06:55 AM
is two full range drivers in one baffle a problem? bbaker6212 Multi-Way 40 26th January 2003 12:05 PM
Copyright ©1999-2017 diyAudio
