| diyAudio Sponsor | ||
What if I change electrolythic bypass cap with one block cap (same value of course)
Will it change anything? Cap is 1uF 63V I want to change that one in 1uF 63V metal poly (axial-yellow-cool) Would it affect sound or something? Maybe it is stupid question |
#2 |
There are a few who would say it will modify the sound a bit but to my ears it wouldnt.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#3 |
Ok so I would not screw up if i test it
Thanx a lot |
#4 |
It will be fine.
#5 |
it wont change anything, but you will learn what characteristics of one type/brand/construction to another if you keep the same value.
Common-cathode stage, fully-bypassed cathode: ![]() Voltage Gain: Av = (mu * Rp)/(Rp + ra)Input impedance: Rin = RgOutput impedance (plate): Rout = (ra * Rp)/(ra + Rp)Output impedance (cathode): Rk' = (Ra+ra)/(mu+1)Input capacitance: Cin =Cgk + Cgp*(Av + 1)Frequency response: f1 = 1/(2*pi*Ci*Rg) - highpass breakpoint due to Ci/Rg f2 = 1/(2*pi*Co*(Rout + Rl)) - highpass breakpoint due to Co/Rout/RlWhere: Rg = the grid resistorNote that Rl is ignored in the output impedance calcuations for the output, not because it doesn't affect output impedance of the overall circuit, but because output impedance is traditionally the impedance of the output of that gain stage looking back into the output. Rl is the input impedance of the following stage, so it is not included. Of course, when calculating overall gain in an amplifier, the loading effect of Rl must be taken into account. In the case of the cathode impedance, Rl must be included because it will affect the impedance seen looking back into the cathode. |
| 2A3 without cathode bypass cap??? | papparazzi | Tubes / Valves | 13 | 25th May 2008 04:06 PM |
| Best cap to cathode tube bypass is ….. | Katapum | Tubes / Valves | 30 | 14th May 2006 11:27 AM |
| Need recommendation for cathode bypass cap | andy2 | Tubes / Valves | 12 | 15th February 2006 07:09 PM |
| Cathode bypass cap ? | woody | Tubes / Valves | 2 | 19th May 2002 05:53 AM |
| Best Cathode Bypass Cap | Mohan Varkey | Parts | 4 | 6th May 2002 08:59 PM |
| Page generated in 0.08263 seconds (74.33% PHP - 25.67% MySQL) with 10 queries |
