diyAudio Sponsor
Old 17th June 2011, 03:27 PM   #1
Default Parmeko gresham transformers specifications
i need parmeko gresham transformers spec,anyone knows is there a booklet or manual i can locate them?
Old 17th June 2011, 03:35 PM   #2
Alastair E's Avatar
Normally with the Parmeko types like the 'Neptune Series' the spec is marked on a plate attached to the case....
I always thought, for their physical size that they appeared a little under-rated....
Parmeko are still going, so maybe a quick mail to 'em will help....
Old 17th June 2011, 04:04 PM   #3
thanz!i m actually would like to readout more about parmeko old products line yransformers,any infos or helps?
Old 17th June 2011, 04:15 PM   #4
thanz!i m actually would like to readout more about parmeko older transformers line products.any infos or helps?
Old 17th June 2011, 09:23 PM   #5
Alastair E's Avatar
Well, All I can tell you about them is they were extensively used in Military equipment...
There are various ranges, some pretty standard EI type transformers, others like the Neptune-Series are hermetically sealed, oil filled devices.
I personally have a few kicking round and have used them in various projects in the past.
Very good quality transformers IMO...Often some on fleagay, however, some are commanding daft money by the 'get-rich-quick' scrappem guys on there....
1950's Parmeko Co-axial 15" BBC speakers tom1356 Multi-Way 35 26th March 2006 04:14 AM
finding out specifications Hayden Subwoofers 14 23rd February 2006 07:59 AM
guitar specifications. electro samurai Instruments and Amps 1 12th April 2004 10:13 AM
Parmeko Oil Filled Transformers Tube (Valve) Power Amp 110V up to 250V mozfet Swap Meet 5 29th October 2002 10:57 AM
Page generated in 0.24570 seconds (23.54% PHP - 76.46% MySQL) with 10 queries
