diyAudio Sponsor
Old 17th June 2011, 01:22 PM   #1
Default ST-70 XLR Balanced Driver Boad
I've looked around and I can't seem to find anything. Does anyone make or have a schematic for a fully balanced driver board for a ST-70 amp?
Old 17th June 2011, 03:23 PM   #2
HollowState's Avatar
The Audio Research circuit is fully balanced. All you need do is not use the inverter stage. Connect the lower 12AX7 grid to the other balanced input. The circuit is in this thread.
Grounding the 4ohm tap
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University
Old 17th June 2011, 07:35 PM   #3
zigzagflux's Avatar
Could check out K&K Audio. With the input transformer, you can run balanced or unbalanced inputs.
K & K Audio - Lundahl Transformers, audio DIY kits and more
Old 17th June 2011, 07:40 PM   #4
There are many options to convert to unbalanced, but why convert just to go through a phase-splitter and be back to balanced?
I'm also curious about differential feedback.
Mystery ST-70 Driver Board Pyre Tubes / Valves 39 23rd May 2011 02:53 AM
St 35 or St 70? scetoaux Tubes / Valves 13 19th February 2011 05:18 PM
College-proofing an ST-70 (aka autobias+ST-70) antiquekid3 Tubes / Valves 15 13th June 2010 03:37 AM
FS: Welborne Labs Alan Kimmel Mu Stage Driver Kit for Dynaco ST70 ST-70 e.lectronick Swap Meet 7 6th May 2009 03:30 PM
New ST-70 Driver board from Blackburn Audio Original Burnedfingers Tubes / Valves 18 27th July 2008 01:28 PM
Page generated in 0.06475 seconds (82.98% PHP - 17.02% MySQL) with 10 queries
