| diyAudio Sponsor | ||
Im thinking about using double triode single pentode compactrons as an literally two tube headphone amp, they are rated at up to 300v b+ so ss rectified direct from wall, and a pair of 2w+ rated output transformers and I have an extremely low profile tube headphone amp?
#2 |
Forgot to say, 6bh11 its what I was looking at
#3 |
No no no no no. Frankly, I just don't see how this continually gets missed by newbies.
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#4 |
Ok, so I'll find a small transformer, part of why I was asking about it as I wasnt sure if that was ok. Was thinking about using a voltage doubler. They kind of seem intended for line voltage at design intended voltage of 125v. Of course I wasnt going to omit fuses etc tho but ill have to see if I can find out why the concept is so bad, is it to increase rejection of line noise?
#5 |
It's not about noise, it's about safety. If you are using or working on a device that is not galvanically isolated from the mains in some manner, such as a transformer, your body can become the pathway for the full energy of the mains circuit to get to ground.
#6 |
Ah so more so worried about the chassis, at least a 1:1 transformer shouldn't be hard to acquire anyway. I got a spare 400va transformer from my main amp but it is way overkill for what I need, in addition to being 400v
#7 |
Any how, any acoustic reason to have physical separation between the pre/driver and the output tubes?
#8 | |
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#9 |
#10 | |
At the least have a 1:1 isolation transformer in place. They're not that expensive. ~Tom |
| Ultimate Integrated Amp - Logical Wings Miracle Drive "USO800-Pro", who have heard ? | tiefbassuebertr | Solid State | 1 | 24th November 2010 05:51 PM |
| MENG Series "EL34B" Integrated Amplifier | stevenscoffee | Tubes / Valves | 2 | 8th July 2008 07:10 AM |
| Denon PMA-520 Integrated Amp "Buzz" | DreadPirate | Solid State | 8 | 9th February 2007 08:39 PM |
| Page generated in 0.11822 seconds (81.98% PHP - 18.02% MySQL) with 10 queries |
