diyAudio Sponsor
Old 15th June 2011, 04:57 AM   #1
Default 6C33C tube socket for GM70 tube??
Hello
Can I use 6C33C tube socket for GM70 tube.
Of course I will have to drill up the porcelain to feet for the GM70 legs.
Did anybody ever tried to use that?
Do the GM leads would match with the socket?
I ask these because only I found gold plated tube socket for 6C33C and not for the GM70.
And it is much cheaper!
Yes I know there are teflon tube socket but the price is not for me at least not now.
If anybody has experience with these please let me know.
Thank you
Greetings gabor
Old 15th June 2011, 05:24 AM   #2
SVStube is offline SVStube  Ukraine
Originally Posted by gaborbela View Post
Hello
Thank you
Greetings gabor
Hi, Gabor.
If you have a chance to make more holes in porcelain, it is no problem with the use of the GM-70.
Serhiy
Old 15th June 2011, 05:34 AM   #3
Go the original holes is in the right place.
I can make them larger but have to be same pin out the the 6C33 tube.
I look at the picture on the net and they are very similar sockets.
To make the holes larger that OK , but to drill a total new hole that is not OK.
Alter I have to replace the connectors etc.
Thank you for your answer
Greetings gabor
Old 15th June 2011, 06:24 AM   #4
New holes do not have enough increase in available. Contacts better to replace.
Old 15th June 2011, 05:14 PM   #5
FullRangeMan's Avatar
This is the BIG problema of the GM70 tube, it do not have a good socket as the 6C33 or the Americans big triodes.
If one had some suited lug connectors that fit the tube pins, a low price solution is use a big capacitor belt, it will lasts forever.
The teflon sockets had great sound effect, but a hot tube as the 6C33/GM70 run at 300șC and after some years the Teflon will suffer.
>Never go to a psychiatrist, adopt a cat or dog from the streets. On the streets pets live only two years average.
Old 15th June 2011, 06:35 PM   #6
If you have a mechanic friend, ask him carved collet contacts to GM-70 pins and insert them into the 6C33C socket.
Old 15th June 2011, 10:35 PM   #7
I have a friend who makes jewelry, I have to talk to him about it.
The rhodium plated is really cheap, about $10 dollars a piece.
Old 16th June 2011, 12:20 AM   #8
You can drill porcelain with either a tungsten carbide drill or a diamond coated one. Go steady, its not easy.
I guess you are asking because you already have septar sockets?
Try these:
PAIR NEW Ceramic Tube Sockets for GM70 GM-70 TUBE | eBay UK
Dont know if they are any good.
Cheers Matt.
Old 16th June 2011, 02:59 AM   #9
Hello
That cost over $50 2PC with shipping.
I can buy for $6 one of a local store the 6C33 socket, not gold plated.
Also I can buy on the eBay the gold plated version and still cheaper and probably would have better contacts.
I have special drill bit for glass.
Thank you very much. Actually what I wanted to know if I can use the 6C33 tube socket for the GM70.
Yes I can I got the answer.
Greetings gabor
Old 17th June 2011, 05:23 AM   #10
nomiconxp's Avatar
My GM70 amp is working with 6c33c socket!
Just opend two holes a litle!
Gabor no problem
6C33C-B Tube Tester Headspark Tubes / Valves 4 13th February 2012 07:12 PM
My first tube amp: 6C33C matsj Tubes / Valves 11 4th February 2011 03:46 PM
New GM70 tube with problem FullRangeMan Tubes / Valves 9 17th June 2010 12:10 PM
Tube socket does not fit tube WRyan Tubes / Valves 18 20th January 2009 01:41 AM
6c33c Tube preamp lawbadman Tubes / Valves 9 26th March 2006 05:51 AM
Page generated in 0.08748 seconds (85.84% PHP - 14.16% MySQL) with 10 queries
