4P1L DHT Line Stage
4P1L DHT Line Stage
Old 27th August 2011, 04:00 PM   #21
mogliaa is online now mogliaa  United Kingdom
mogliaa's Avatar
4P1L DHT Line Stage
Again. Have done some testing as I posted in the 26 pre-amp thread.
Attached is my modular test bed using Gluca's board for the IXYS Mosfet CCS. Filament and HT supply is regulated from my lab power supply.
So, after a testing several operating points I came up with the best one in terms of distortion:
Ia=25mA, Va=77V, Vg=-5.8V (LED array combination of amber and red ones)
THD = 0.019%. Slightly better compared to my best 26 valve measure. I just tested one 4P1L which I had at hand, may need to check if there is a more linear one, however, as it stands the result is really good compared to other valves!
Any suggestions around trying a different op point? What about biasing around -15/-20V and increasing the anode voltage? Will improve distortion?
Ale
"A mistake is always forgivable, rarely excusable and always unacceptable. " (Robert Fripp)
http://www.bartola.co.uk/valves/
Old 27th August 2011, 04:16 PM   #22
Alastair E is offline Alastair E  Wales
Alastair E's Avatar
Ive played around with the 4P1L....
Wow! Incredible Microphonics! That things ring like a bell if you make any harsh vibration, and if you tap 'em they ring for many seconds!
I was running about 80V anode and around 25mA with a MOSFET on top, and std cathode bias un-bypassed.....
Das Beste Oder Nichts
Old 27th August 2011, 04:24 PM   #23
mogliaa's Avatar
4P1L DHT Line Stage
Hi Alistair,
:-( that doesn't sound very encouraging though. I did tap it whilst driving it with a 1kHz sine signal and couldn't see any traces of ringing in the scope...
Well, I got very close with the operating point anyway!
Will have to build and test this on a real amp...
Ale
Old 27th August 2011, 04:51 PM   #24
Alastair E's Avatar
Maybe its the tubes I was using, I have 4 'svetlana' ones and 4 of some other make, They all rang like bells!--Although slightly different tunes!...
I had arranged the test as the first stage in an amp just to see what they would be like.
I was using a SLA batt to supply the heaters via current limiting resistor, and had it triode-strapped....
Old 27th August 2011, 05:00 PM   #25
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
4P1L DHT Line Stage
I am afraid it is overkill to use power output tube for the first stage in an amp, unless it is also the last one.
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 27th August 2011, 07:43 PM   #26
Alastair E's Avatar
So--Probably overkill to use one in a Line-Stage too you reckon...?
Old 27th August 2011, 07:45 PM   #27
Wavebourn's Avatar
4P1L DHT Line Stage
I did not try that, but in output stage they did not ring.
Old 28th August 2011, 01:35 PM   #28
hihopes is offline hihopes  South Africa
I think that in a power-amp, the step-down ratio of the output transformer probably lowers the level of the ringing considerably. (At leaast I hope so! as I intend to build one soon) As a preamp, they ring if any loud noise is made in the room, although admittedly, I have done nothing in the form of damping for them, as this pre is still an experiment.
Old 31st August 2011, 08:13 AM   #29
pietjers is offline pietjers  Netherlands
pietjers's Avatar
The idea of putting leds in the cathode is to give it constant voltage. But leds have rather high dynamic impedance. I did some measurements to determine the Rdc of leds by changing the current through them and measure the voltage difference and found the following values: Red 5 Ohm, Green 15 Ohm, Yellow 18 Ohm and Blue 37 Ohm. When you put a string in the cathode these Rdc values add.
Mogliaa:
In my ears bias with leds alone sound only so so.
Try to bypass the leds in your schematic in post #21 with good quality foil types and listen to the differences with/without. I am sure it will put a smile on your face!
My recipe is to start with something big and bypass it with several capacitors from large to very small, for example: 10u mkt or pp, bypassed with 2.2u pp, then 100n polystyrene, 10n polystyrene, 3n Russian Teflon, 560p Russian Teflon. Or whatever types you prefer or have on hand! Even the smallest values in the pF region give an easy to hear improvement, so don't forget these.
Peter
Old 31st August 2011, 12:04 PM   #30
My LED's are bypassed with new OSCON organic caps. I tried quite a few different types here and these give best balance and clarity in my system with my current operating point. They are ULTRA-low ESR. No small bypass caps needed.
4P1L DHT Line StageHide this!Advertise here!
All DHT Phono Stage Steve Cresswell Tubes / Valves 32 2nd April 2013 06:24 PM
one stage DHT amp Jaime Tubes / Valves 2 18th October 2010 12:31 PM
Which DHT for Line stage? andyjevans Tubes / Valves 15 26th March 2009 01:10 PM
Aikido line stage - plus phono line stage cjkpkg Tubes / Valves 1 22nd November 2008 09:50 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 04:07 AM
