diyAudio Sponsor
Old 12th June 2011, 09:41 PM   #1
tricomp is offline tricomp  Denmark
Default 9001 variant of Acorn 954 Pentode
Did someone use this UHF-tube for audio?
The 9001 has a user-friendly B7G base and I have a few of them that I would like to use in a RIAA-amp and a LINE-ditto. Possibly connected as triodes.
Your thoughts, please.
rgds,
/tri-comp
Old 13th June 2011, 07:36 PM   #2
Note that RCA suggests the 9001~9003 to be used in Resistance-coupled audio amps.
But, did anyone do it?
Sorry, the reduced quality of the attached file is necessary because of forum rules that doesn't permit pdf-attachments above 195.3Kb. That's NOT a lot!
The original page may be found in 'RCA Guide for Transmitting Tubes 1942'
/tri-comp
hi cap or variant psu rocco gibralter Power Supplies 0 13th August 2009 10:55 PM
955 Acorn tubes rdf Tubes / Valves 10 6th April 2009 02:53 AM
A small no-fuss pentode/pentode SE amp Tubes4e4 Tubes / Valves 13 1st January 2006 05:16 AM
Inverting GC variant mauropenasa Chip Amps 38 6th July 2005 01:42 AM
Aleph P or BOSOZ variant stefan Pass Labs 14 10th September 2002 09:27 PM
Page generated in 0.06634 seconds (67.32% PHP - 32.68% MySQL) with 11 queries
