| diyAudio Sponsor | ||
My pair of JJ Matsushita 5AR4 supplying my SSHV's have developed a mechanical buzz after around 1000 hrs. The SSV is set for 60 mA each channel, the power transformers are hammonds 269JX, the transformers are not buzzing or hot.
I've had good luck with JJ's in the past but, I think I am going to source a pair of japanese 5AR4's. Sound lke the right decision? |
#3 |
50 uf to 1.5k resistor to 5uf to SSHV . Shouldn't be too much capacitance, No issues show up with PSUD. The problem wasn't there at first. Going to try some Japanese 5AR4, if it is still there I'll dig deeper. I just don't remember ever having a retifier buzz/hum mehanically, hence the post.
#5 |
My original post has a typo, these are just plain JJ new 5ar4's withh 1k hours on them. The datasheet from JJ claim 60 uf, but I can certainly try lower.
http://lib.store.yahoo.net/lib/thetu.../JJ-GZ34-S.pdf |
#6 |
As Philips owned both Mullard and Amperex, I'd say this data sheet is reasonably definitive. It shows a max. I/P cap. value of 60 μF.
Unfortunately, JJ has come to stand for "Jamona Junk", far too often. The OP's experience may be 1 more example of the phenomenon. As the fact that Matsushita made their 5AR4s with Mullard tooling is quite well known, those tubes carry hefty price tags. I suggest you contact a reliable tube vendor, like Jim McShane and purchase a properly culled Chinese or Russian specimen.
Eli D. |
#8 |
Wow didn't realize how expensive Matsu 5AR4s had gotten but I found a decent deal on NOS 80's Hitachi 5AR4's, going to try them.
Thanks |
#9 |
You could buy a lot of SS diodes for $15 !
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#10 |
It depends on the SS diode in question. A 1200 PIV/5 A. silicon carbide Schottky by Cree costs 8 USD.
Eli D. |
| 5C8S rectifier psud2 modle/rectifier information | ryuji | Tubes / Valves | 1 | 14th March 2011 04:54 PM |
| buzz buzz... probleme with VSPS | 6ri.l | Analogue Source | 0 | 19th August 2010 04:41 PM |
| converting tube rectifier to solid state rectifier. | tubo | Tubes / Valves | 26 | 24th December 2009 12:12 AM |
| Melos triode and computer as source: BUZZ BUZZ BUZZ | zigo3 | Tubes / Valves | 4 | 28th November 2007 02:11 AM |
| Anybody heard about Tarzian Silicon Rectifier for Tube Rectifier Replacement? | zxx123 | Tubes / Valves | 4 | 21st February 2005 04:02 AM |
| Page generated in 0.08132 seconds (87.24% PHP - 12.76% MySQL) with 10 queries |
