| diyAudio Sponsor | ||
One of the 10 commandments of tube design is that you don't want to invert the phase from input to output.
Yet I see a lot of line stages have one tube for gain, which would invert the signal going forward (I'm not talking about CFs). Even from noted designers. So at the end of the day, how important is it not to invert phase, if both channels are kept the same, and why? Thanks in advance, Jon |
#2 | |
Regardless of the source, be it vinyl records, tapes, digitized CDs, downloaded music or off the airways, it is impossible to know the original phase reference. So the best we can do is to keep both channels equal and, using our ears, reverse speaker phasing to determine which sounds best. But this becomes a double edged sword that will drive you nuts because now you have to do it for every piece of music you listen to. So forget about it! Of course, keeping your own local system phase accurate is quite simple with an oscillator and an oscilloscope.
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University |
#3 |
its not important. Its one of those fetishist audiophool canons that bears no scrutiny...
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012 |
| within passband phase inversion | speakerdoctor | Multi-Way | 4 | 5th July 2010 03:57 PM |
| Passive phase inversion? | TequilaKez | Parts | 4 | 6th October 2008 01:38 AM |
| Avoid polarity inversion | MaXiZ | Everything Else | 7 | 3rd March 2004 05:55 AM |
| Polarity Inversion circuit | ashok | Everything Else | 17 | 5th April 2003 11:32 AM |
| Page generated in 0.06907 seconds (70.74% PHP - 29.26% MySQL) with 10 queries |
