| diyAudio Sponsor | ||
Recently, I DIY the Toccata Phono MKII preamp and found the amplificiation of the amp is far lower than expected. I am using Dynavector 17D3 MC phono and connect the Preamp to a headphone amplifier. I turn the volume to maximum and merely hear the music. I checked the voltages and found nothing adnormal. Attached the schematic with voltage shown. Please advise the possible cause of problem....many thanks.
#2 |
After several trail, I find the cause of problem, since I couldn't find 2SK147, I use Vishay J/SST201 instead. May be it is not compatible with 2SK147, it doesn't amplify the signal. what shall I use to replace the 2SK147?
#3 | |
работник
You can get even more gain, and better sound, if you connect them up as shunt-cascode - search in the Analogue Source forum for Werner's OP637 RIAA amp, with K369 first stage. This circuit gives an idea of what that JFET can really do. You can use passive RIAA eq, followed by a valve in the second stage. |
#4 |
работник
I found Werner's circuit.
folded-cascode FET/opamp MC phono Keep Q1 and all the parts to the LEFT of it. Throw out the op-amp. Capacitor couple to the 6GK5 grid of the Toccata - you can delete the first stage Valve 5842. This front end is lower noise, better sounding, and highly resistant to EMI and power line noise, compared to the original, IMHO. |
#5 |
Thanks Rod
Will find some K369 and put in the Toccata first, and try your suggestion later to see which one sound better. |
#6 |
работник
If you put the K369 in the Toccata, check that the 5842 Anode voltage appears as shown on Thorsten's drawing. This is very important - and it is also easy to adjust.
The 50 ohm resistor in the JFET source can be varied until the 8V drop across the 10K anode load resistor is correct. |
#7 |
Hi Rod
You mentioned that voltages were shown on Thorsten's drawing, I can't find this drawing, can you show me the link? I would like to verify voltage on other stages. Thanks |
#8 |
работник
Hi, I am looking at the drawing you posted in post #1. Thunderstone is Thorsten's old Audio name.
The voltages I mean are 230V and 238V marked in the anode circuit of the 5842 |
#9 |
Oh,thanks
Those voltages are my measurement on my amp. I will check the voltage after replace the JFET. |
#10 |
работник
If the values you measured are 230v and 238v, this means 0.8mA in the JFET. With a K369, try to get 4 to 6mA to flow (change the 50 ohm). The noise will reduce between 1 and 4mA and the sound will be better.
| Diy Tube Phono Preamp | alexmoose | Tubes / Valves | 39 | 11th December 2011 08:43 PM |
| What is the best DIY phono preamp projectY | Justinasia | Analogue Source | 37 | 2nd December 2006 08:22 PM |
| Toccata Phono Preamp | Algar_emi | Tubes / Valves | 19 | 11th November 2006 01:48 AM |
| Help for newbie building Toccata preamp | summilux | Tubes / Valves | 3 | 26th November 2005 07:33 PM |
| Page generated in 0.09818 seconds (78.77% PHP - 21.23% MySQL) with 11 queries |
