| diyAudio Sponsor | ||
I have some 12K:4R SE OPTs, likely from old radios with EL95. Can this be used as PS choke?
If yes, what to do with the secondary (leave open?) DC resistance of the primary is rather high at 360R but it would probably end-up in a low-wattage monoblock with 30-40ma current draw so voltage drop would't be that horrible. Paralleling the primaries of two transformers would reduce DC resistance but would inductance also be lowered? |
#2 |
Will work fine - a single-ended transformer is a choke with a secondary winding...
| Where can I get a cover for the OPT and PS | WildOne | Tubes / Valves | 2 | 25th May 2011 12:56 AM |
| Use P-P OPT for SE? | 807tubenut | Tubes / Valves | 12 | 13th August 2010 08:01 PM |
| PS choke magnetic induction | Klimon | Tubes / Valves | 3 | 9th April 2007 08:45 AM |
| Swinging choke vs std. choke in PS | Curly Woods | Tubes / Valves | 2 | 5th March 2007 08:30 PM |
| Ps Filter Cap or Choke? | Dr.Frankenstein | Power Supplies | 3 | 11th March 2006 07:51 AM |
| Page generated in 0.05895 seconds (66.21% PHP - 33.79% MySQL) with 10 queries |
